- Joined
- Dec 10, 2023
- Messages
- 65
Hi everyone,
I picked up a 2001 tahoe a few days ago. Absolutely love the truck and it’s pretty much fully loaded aside from missing heated seats.
Once it gets warm (atleast i haven’t noticed it as much when it’s cold) the trans shift flares a bit from 2-3 and when passing someone up it’ll slip a bit. No codes or anything, drives smooth aside from engine/trans mounts being bad. I should add the transmission fluid is nice and red, maybe a little worn but nothing too bad. I have to change it soon and i was wondering if there is anything else i should change to maybe help fix this while im down there. Also, 2-3 only flares while under heavy throttle.
Should add, it has almost 242K on it. Engine is as smooth as butter.
