Newly-rebuilt 4L60E lost 3rd gear within 20 miles, sigh...
Nothing new, life and work sucked me away from this project - which stinks since I'm down a vehicle until I get this back together.
Next up is vacuum testing the pump, when I get a chance (and its not 8 degrees F in the shop.)
I'm baack, hahaha
Only thing I've found blatantly wrong so far is that we got the pump ring's oring and steel sealing ring installed reverse order (not that hard to to imho, given the low-res pics in the books. So the Steel sealing ring was in the groove, and the oring was between it and the pump housing. In my mind I can't see a big difference, but I'm no engineer and it was clearly wrong - hopefully that was "the problem".
Reassembled the pump properly (all clearances within specs) and vacuum tested the pump, and it's great - nothing below 18" vacuum.
Reassembled the Input Housing with new frictions all around and new 3-4 steels. 3-4 clutch pack has 7 frictions with .026" clearance after air checking and seating several times.
Air tested all 3 clutches, and all hold nicely.
Next Up, starting on the case and low-reverse clutches, etc.
@clinebarger - Looong story short, SUCCESS!!!
Assembled the rest of the transmission, triple-checking everything (https://www.youtube.com/@transmissionbench7842 is a terrific resource).
As far as I can tell, we made two mistakes, both kinda-sorta understandable (I know, I'm rationalizing...)
Mistake #1: When assembling the pump, we got the sealing ring and o-ring reversed. My son said it's because the book says to "install the slide seal ring and rubber support ring into the slide groove", and we did it in literally that order. I'm betting that this resulted in less than wonderful pump performance, which caused the 3-4 clutches and band to slip.
Mistake #2: We installed one steel too many in the Low-Reverse clutch pack. My thinking here is that we mistook one of the original steels for a spacer plate. This caused the clutch pack to run hot, which scorched it.
Everything else in the transmission looked and checked out within specs.
But wait, there's more, lol.
After reassembling and reinstalled the trans, we hooked up the Quick4 controller, and it started acting up - clicking solenoids, freezing screens, etc. So we triple checked the wiring, the solenoid resistances, etc, no joy. Contacted the guys at https://www.usshift.com, they said send it back and they'd check it out. They couldn't replicate any troubles with the controller, but still sent us a new one as a courtesy - and it works GREAT! I have no idea what was up with the first one, it worked fine while the first rebuild ate itself...
At any rate, all is well now, the transmission works like a champ, and we're slowly adjusting the shift points and firmness. Cool thing about the Quick4 is that it will allow 4 different "tunes", like "Normal", "Towing", "Valet" (never shifts above 2nd), etc.
Been a long drawn-out project, but I'm still glad we did it ourselves - my son and I both learned a lot, and had a (mostly) good time doing it.
Change "valet" to "drift" because if you're trying to drift you also want to keep it in 2nd
