Ultra Seq IIIG
As you can see from the photos, Ultra is significantly better at keep the engine clean and deposit free. A great example of why better oils are often worth the added cost in higher performance applications. It's also why Mobil 1 is used in so many high performance engines.
My perspective has always been that Mobil 1 is average at best at preventing cam lobe wear, but excels beyond most all other oils in high temperature deposits. Ultra may have raised the bar here. (non boutique brands). Oils like Synpower, Castrol Syntec have been surprisingly poor in this area until recently when Synpower finally obtained GM 4718M (still no HTO-06). Amsoil & RL are both excellent, obviously.
One of the improvements for GF-5 will be high temperature deposits. The current standard is not that great IMO.
Seq IIIG is a high temperature wear and deposit test. Most of the tear down photos I've seen on here never show the pistons.
Two good photos of Pennzoil Ultra vs GF-4 Standard.
GF-4 Standard
GF-4 Standard
