well..?all i have to say is back in the eighties when i was in high school i had a 69 chevy and i did an intake swap and i used penzoil for the first time.the engine was pretty clean on the inside.3 thousand miles later i wanted to change intakes again and there was a build up of crud on the inside of the lifter valley that wasn't there 3 thousand miles ago.i never used penzoil again.but,with todays oil standards and formulations i would'nt be scared to use penzoil again.when i did a camshaft swap later the build up on the inside of the lifter valley never got worse or changed.thats my only experience with it.
