It's unseemly! Unseamly, even.I'm more concerned about the seam than the glue
Contact RP and see if they will warranty it![]()
The Fram has a different construction, and in the past I considered it, ultimately deciding to stick with Royal Purple and Toyota's TRD filers. The $2.00 or $3.00 saving is not important.the seam is all melted together in construction and the glue is on the filtering side of the element. i would use it. to save some money next time, the gram endurance from walmart is the same filter for a little less money.
interesting, what is different about it?The Fram has a different construction, and in the past I considered it, ultimately deciding to stick with Royal Purple and Toyota's TRD filers. The $2.00 or $3.00 saving is not important.
Royal Purple on the left. For a starter, the end caps and gaskets are substantially different. Right or wrong, I refer metal end caps and I like the thicker and softer gasket on the RP.interesting, what is different about it?
I find it puzzling, Champ/Fram have such a variation whereas TRD and Royal Purple cartridges are identical in assembly materials. When it comes to production rate, I'd think rate progressive stamping of the steel endcaps would yield higher volume compared to injection molded endcaps which would be naturally slower rate due to the mold injection cycle. I wouldn't be surprised if they're sourcing the plastic endcaps from a secondary supplier in volume to minimize cost.Royal Purple on the left. For a starter, the end caps and gaskets are substantially different. Right or wrong, I refer metal end caps and I like the thicker and softer gasket on the RP.
For the premium it should have better quality on the seam. Throw in the somewhat sloppy glue job & you have a good case for replacement.The more I look at that seam, the more it bothers me. It's not worth being concerned about it ... which I would be if it was on the engine. I won't be using it. Thanks to all for jumping in.
Hope y'all have an enjoyable Memorial Day weekend.
I've had a number of problems with the threads on Fram filters over the years and got one with a cut across the gasket which caused an oil leak. After that I stopped using them and try to go with OEM filters. Or NAPA Gold.I’ve cut open several used Fram Endurance filters that look similar. Sloppy construction with glue everywhere, funky seam and badly cut threads. I no longer use them.
I’ve had two or three Endurance filters with giant slivers of metal in the threads. Had to carefully remove them with a pick. Now I inspect every filter I buy. OG Fram Titanium/Ultra and Premium Guard built filters are my go to recently.I've had a number of problems with the threads on Fram filters over the years and got one with a cut across the gasket which caused an oil leak. After that I stopped using them and try to go with OEM filters. Or NAPA Gold.
