Would you buy a Fram if it had metal endcaps?
Originally Posted By: KevGuy
If FRAM put metal end caps on the OCOD, I would be devastated.
You crack me up sometimes Kevguy
I buy and use orange cans occasionally now, I have no FSD, so I imagine I'd use them with metal endcaps too.
Greatly prefer Motorcrafts though if I can get one for my application.
Originally Posted By: BlueOvalFitter
Originally Posted By: asand1
If john force use it, it must be good right?
That's what one of my cousins said,as to why he uses the FRAM OCOD!
LOL ... because there's a big blow up OCOD at the drag races, it must be the top tier filter used by all professional racers. This is the power of advertising ... nothing more.
"Devastated" if the OCOD was to use metal end caps.
[Kevguy] Don't fear the orange can. [/Kevguy]
Seriously,he said that! His exact words,"If it's good enough for J.F then it's good enough for me." Of course he is set in his ways.
After years of using PureOne's....I recently purchased the Fram 'Ultra'....with metal endcaps, synthetic media, excellent construction and great efficiency. Its the only Fram I will use and its good for up to 15K.
At $8.97 at WalMart....its one of the best buys out there in the the high tier filter market.
I will use it for two 7,500 OCI's....with M-1 0w20.
Tell your cousin to look at the Force cars next time he's at the races and see if there is an OCOD on there, I bet not.
Actually all funny car and top fuel cars use a Fram oil filter. Years ago they used an HP series spin on. Now they use a Fram canister filter specifically desinged for these engines.
I remember seeing those HP filters on there. I wonder why they did away with them? And,why do all T/F and F/C use FRAM only?
Quote:
......Actually all funny car and top fuel cars use a Fram oil filter. Years ago they used an HP series spin on. Now they use a Fram canister filter specifically desinged for these engines.
And because of pressure developed, true 'racing filters' by design are basically sieves. Wouldn't let the fact that Fram racing filters are used for drag racing influence my choice of oil filters for pc use.
My point is that they don't use the ocod.
Same here! I got my Fram Ultras for 5.75. Im no Fram fan but the ultra is a good filter.
Volk,are you going to do the same,use it for (2) OCIs?
Probably not at first, I'm running a cleaning OCI of 7.5K with PU or PP. After that I might.
Can you please explain how PP or PU cleans? Sure,I can Google it but coming from an actual person whom knows first hand is better. I might need/want to do this.
PP/PU have the additives and base oils to do some good cleaning. Most dont show up on a VOA/UOA. Are they better than other oils? Well their marketing department seems to think so. Look at this filter from a 8K run on PP.
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2871724#Post2871724
But,if someone has been doing the required OCIs,an engine should not need this cleaning or look like what was in that oil filter. Or,is this more like a PM thing?
Under normal operating conditions and no mechanical problems, an engine should not need cleaning. I just had some gaskets in my taurus replaced, was leaking some coolant into the oil so I'm flushing the rest of the contaminates and then cleaning it up just because with PU.
I still cant believe that fram held up that good loaded!!! Maybe they are not all that bad.
I will be sure to cut open the next filter from that engine! Its a fram ultra tho
