Thank You both! You are great!
The efficiency test should shed some light on this question. Relatively speaking.Thanks again,,, but the hard question will be which filter will make my engine last longer.
@Ascent Filtration TestingThe efficiency test should shed some light on this question. Relatively speaking.
Looking like next week for the video. Hoping to get the tests done by Friday evening, just depends on how fast I can get some other tests run. Might have to do a pre video because, this test is much more complex to run. I doubt anyone will want to watch a 45 min video on filtration lolAny updates on when the video on this testing might be available? I am looking forward to it![]()
I'll pm you a few names and y'all can get a zoom room.I doubt anyone will want to watch a 45 min video on filtration lol
To stir the pot ant that is the only reason ,, Why have I seen many 350,000 to 400,000 mile engines running quick lube oil and house filters.The efficiency test should shed some light on this question. Relatively speaking. View attachment 43835
Don't mean to go off track from the thread focus, but regular oil changes are part of the equation to keep the sump oil cleaner - dumps what the filter can't catch. If the sump was dumped every 500 miles you wouldn't need much if any oil filter (as an example).To stir the pot ant that is the only reason ,, Why have I seen many 350,000 to 400,000 mile engines running quick lube oil and house filters.
I only test existing filters for quality control or QA and try to identify defects and process improvements, help manufacturers with R and D for filter prototypes/products, and run comparison testing studies for companies with large fleets/engines to optimize the life cycle of their assets by finding the best preforming filters among a large convoluted set of choices.To stir the pot ant that is the only reason ,, Why have I seen many 350,000 to 400,000 mile engines running quick lube oil and house filters.
I'm glad you enjoy them! Yes, ZeeOSix is very knowledgeable on filters and his insight on this thread has been absolutely indispensable.Appreciate the videos and the efforts to not only perform the tests but recording and editing the videos.
I also appreciate z06's commentary as to the gallons per minute and how much an average engine pumps through the filter. A little context.
I can easily imagine the volume of 13 gallon milkjugs, but 49.5 liters, no so much.
Sorry, I can't click like buttons on you tube or FB or the like, or subscribe, it's a personal problem.
Yes I am stirring the pot because operation when the engine has reached a stabilized operating temps will give the longest engine life as compared to short time and mile use no matter the quality of the oil filter.CT8... In those cases.. . It could be that vehicles run a lot of miles per year and they see routinely long trips could add up miles very, very quickly...
I have a neighbor with a late 80s Ford Escort with. . . Get this.... 1,000,000+ miles.... My neighbor told me that they car was used by his mom for a good number of years delivering papers daily. That made it possible for those miles to add up.
Would you please substantiate your vague claim: define, describe, and most importantly substantiate with data, the relationship between stabilized operating temperatures, time, longest engine life, "short time", mile, and oil filters.Yes I am stirring the pot because operation when the engine has reached a stabilized operating temps will give the longest engine life as compared to short time and mile use no matter the quality of the oil filter.
Z, This is an interesting graph and I agree with you.^^^ There seems to be a sweet spot in engine and oil temperature in which wear is minimized. If an engine was always short tripped vs very long trips, then it seems there could be an increased level of wear over time - at least with cylinder/ring wear. Might be the same with other engine parts.
The oil filter doesn't have anything to do with that of course, but the oil filter is still helping in terms of removing any debris in the oil which can also cause a separate wear mechanism (3-body wear in moving parts), regardless of where the debris comes from. The two are really separate scenarios going on at the same time.
See info in post 172 and 173 in this thread:
https://bobistheoilguy.com/forums/t...ae-30-cylinder-wear.75778/page-9#post-2713636
a yea late to the party
Donaldson P577066, PF63 equivalent. Claimed 50% efficiency at 6 micron. Sounds like the "Blue" filter media. That would have been an interesting contender.
