Yes how often the filter goes into bypass seems to be a real concern.
I was going to make a post in this thread on similar grounds as what @iunderpressure posted. The oil filter bypass debate with Subaru has been raging for over a decade and while it is one of heated discussion, to date no one has come up with a definitive answer as to why things are the way they are and how the variables apply to aftermarket oil filters.
Without turning this into another bypass argument thread (and believe me it can and likely will become another one of the endless number of argument threads if allowed to) here are the basic facts we do know:
- The Subaru OEM oil filter for 4-cylinder engines has maintained the usage of a 23.2psi bypass valve since model year 2009 when Subaru began using positive displacement oil pumps that flow at max capacity of 14.5 gallons per minute and the OEM oil filter was created to accommodate that output.
- The primary arguement is that ALL oil filters must have a bypass valve setting of 23.2psi or higher (like Wix's 27psi setting) or else, with no variables related to the dynamics and performance of other oil filters taken into consideration. The common counter-arguement is that a filter with less restrictive media and/or higher flow and/or lower delta-P, etc can utilize a lower bypass psi to no negative impact compared to the higher bypass filters.
If they are willing to respond (and you are certainly not obligated to engage in this discussion) I would like to ask @Ascent Filtration Testing and Ascent Filtration Testing alone what their thoughts might be on this topic should they be able to share any technical expertise they have on this specific subject. Li
