Originally Posted By: kschachn
Originally Posted By: Fasttimez
I run Royal Purple HPS 5w30. I'm not really seeing what everyone is talking about when it comes to price. I order it from Summit or Jegs, cost $8.30 per quart for top of the line HPS Synthetic. By comparison, WalMart has Pennzoil Ultra Platinum 5w30 for $7.98 per quart, Mobil 1 5w30 for $7.03 per quart, Castrol Edge 5w30 for $7.97 per quart, Quaker State Ultimate Durability 5w30 for $7.33 per quart.....so where is the HUGE price difference between Royal Purple's top notch HPS line, & the other off the shelf "synthetics" ? I'm pretty sure Royal Purple HPS is more "synthetic" than all those other off the shelf 5w30's also with a better add pack to boot. Also, when you compare RP HPS to the price of AmsOil, Redline, Motul or any of the other boutique oils, they are nearly DOUBLE the price per quart of RP HPS. I'll continue to run the RP HPS & RP filter in my truck. These prices I quoted are directly off the shelf at my local WalMart.....
As is usual when price is discussed, a bit of disingenuous comparison creeps in. Those prices for the other brands at Walmart are for the single quarts, but who in their right mind buys oil like that? Please compare the price to a 5-quart jug of Castrol or Mobil 1 where the per-quart price drops very close to $5 without rebate.
And speaking of "synthetics", I'll put Castrol 0W-40 up against RP 5w30 any day. Just the number of actual specifications the oil carries will tell you everything you need to know.
Why do some people get so whacked out when discussing this oil?
Let's do a comparison shall we......looking at the VOA for both oils, the 0W-40 looks kinda WEAK. Also my truck takes 8 quarts of oil, so should I buy 2 5qt jugs from Walmart at $50-$60 dollars or buy 8 qts of Royal Purple for basically the same amount ? At some point I'm going to need single bottles of the other stuff.
