... or texting while driving.For me it's roadsalt ...
Me too. I know it’s in jest but when I first joined (and even now) it was quite helpfulCome on, list 20 of 'em for us !Love it when you do that !
Of course-my 5.3 should have blown up running 0w20 pulling a 5,000 pound travel trailer up to 10,000 feet elevation on a 90 degree day.....We all know more than the engineers that designed our engines….right?
The 5W-20 grade started to show up en-masse in domestic passenger car applications for CAFE in the late 90's, early 2000's with Ford really leading the charge with the Modular, but they back-spec'd a whole list of engines that were validated to be OK on 5W-20 but had never spec'd it.Al said:Yes I realize that. But read my post. The switch was made around 2000. Wish I could find the SAE pub tghat discussed engine life..
Only once you get down below 2.6cP HTHS. That's why Ford was able to back-spec engines from the 80's to 5W-20, because 5W-20 has an HTHS of 2.6cP. It's when you get down to 0W-16, 0W-12 and 0W-8 where the HTHS is much lower that you have to start increasing bearing surface area.Al said:Bearing surface area needs to change3 with lower viscosities. To accomodate load/rpm/viscosity graph. But we are talking in reducing from 10ish to 8ish cSts.
No, but the floor of 2.6cP for HTHS is the threshold where you need to make engine design changes, which I think is an important distinction. The old monograde SAE 20 oils had a higher HTHS, but there were other xW-20 grades available, probably the most common being 20W-20, but there was also 15W-20 and 10W-20 and even 5W-20 (the original M1).Yes but SAE grade requirements have changed numerous times since then. Today’s 20-grade oils are not the same as they were 50 years ago.
Good post. Some of that comes back to me now.The 5W-20 grade started to show up en-masse in domestic passenger car applications for CAFE in the late 90's, early 2000's with Ford really leading the charge with the Modular, but they back-spec'd a whole list of engines that were validated to be OK on 5W-20 but had never spec'd it.
The Japanese had already been experimenting with this, and thinner, at the time.
5W-20 was not a common grade in the passenger car scene until Ford really took it mainstream, but of course the original Mobil 1 was a 5W-20, and the SAE 20 grade was around for cold climate use, as well as 5W-20, 10W-20, 15W-20 and 20W-20 since before the 2nd World War.
Good pointWhy not pocket the fuel cost savings over the life on the vehicle, which do add up over the years and miles?
I guess that the thinner viscosity does not protect better by itself. Thats why I like to use the heavier oil with the higher moly and boron.Don't overlook the additive package. Many anti-wear elements are built into the additive packages, some of which help "strengthen" the thinner viscosity oils that are frequently used today.
Plus, no engine maker designs an engine for a single grade of oil either.The issue comes in when people say that an engine is “designed for” (as in requires) a grade
Then why in different countries the same exact engine has different list of allowed viscosities?Its long term use of non recommend weight of oil that can cause a problem
