The Glenda ESP Reaffirmation Thread.Thank you!!
We had a noisy Subaru (1998) and switched to that. Noticeably quieter.I wonder how well castrol EP would fare.
That's been my general experience with Castrol oils. They quiet engines down even if it's the same grade.We had a noisy Subaru (1998) and switched to that. Noticeably quieter.
I will elaborate on my previous vote for Mobil 1 ESP 0w30. This should happen after the consumption stabilizes from Valvoline Restore and Protect. So similar consumption with Valvoline Restore and Protect and then experimenting with others for interval 5, 6?Mobil 1 ESP 0W30
Years ago I had my buddy run this in a total beater Subaru EJ253 Legacy cvt and it completely halted the oil consumption after many oil changes. Probably 100k miles worth of 10k oil changes and redline daily. EJ253 having larger oil ring spaces than the FB, it was still impressive to me at the time.
The now defunct Magnatec was very accomplished at this.That's been my general experience with Castrol oils. They quiet engines down even if it's the same grade.
Unfortunately, Valvoline Extended Protection was likely the oil responsible for the oil consumption developing in the first place.Royal Purple would be a fine choice or Valvoline Extended Protection. Havoline Pro-Ds,
Unfortunately, Valvoline Extended Protection was likely the oil responsible for the oil consumption developing in the first place.![]()
Exactly. The design may lend itself to the deposits, but not all oils are created equal or resist the deposits forming.The engine’s susceptibility to piston deposits is irrelevant to determining the effects of the multiple oils used.
500-35k miles Mobil 1 Full Synthetic 0w40 (.25qt/5k mi)
35k-60k miles Valv. EP 5w30 (.25qt/5k mi)
60k-100k miles Valv. EP 5w30 (1 to 2.5 qt/5k mi)
From that data, I think it is very likely that the piston deposits significantly worsened while using Valvoline Extended Protection. Valvoline Restore and Protect later reducing consumption to .75 qt in 5k miles likely indicates that the earlier high oil consumption was not largely due to wear, and that Valvoline Restore and Protect likely achieved this by reducing piston deposits. If this theory is rejected, what is an alternative theory? Poor engine design does not seem like a viable theory because it has no apparent ability to explain the data. The engine design was a constant. Oils used varied, as did oil consumption.
“The design may lend itself to the deposits……..”
I just meant the information that Glenda supplied.Data?
I didn’t create new data. I summarized parts of Glenda’s data and gave very simple and cautious explanations for what I think happened.Your “data” doesn’t add up.
I agree with what you said that the engine lends itself to (piston) deposits. Most engines that with much less tendency to that should not have noticeable piston deposit problems with 5k mile OCIs.If it did then every car owner who’s used Valvoline Extended Protection for 5k mile OCIs post-factory fill should be having noticeable deposit problems and oil usage.
I’d love to see that too. I would not expect Mobil 1 0W-40 FS to have kept the pistons factory new in Glenda’s engine. I don’t think it can be safely said what the outcome would have been if that oil had been used for the first 100k miles.And I would love to see pictures of the pistons and rings in the OP’s Outback after 36k miles of Mobil 1 0w40. We know that won’t happen but I seriously doubt they were “factory new” at 36k miles as you’d like everyone to believe.
My gut says the Valvoline Extended Protection accelerated the process but no way to know for sure. Around the time I switched to Valvoline the FS 0w40 was going through the formula change if I recall correctly. I tried the new Valvoline Extended Protection and was impressed with how my engine sounded and stuck with it(nothing scientific). Looking back I think Valvoline uses a great add pack but mediocre base oils. Again I’m going by my gut.
I’m really impressed with how the ESP has been doing in all my other vehicles and the vehicles I maintain. Really looking forward to the next stage of this test.
I hope not as that’s not my intent. I try to always post it’s an opinion when I don’t know for sure.Be careful, in a month it could be gospel here that Valvoline uses lower quality base oils and the truth is we don’t know.
You are right add packs and used oil analysis are great.
In your case, I wonder if you would have seen a difference using EP HM which is GTL.![]()
