Originally Posted By: SuperBusa
Originally Posted By: BuickGN
Seriously guys, how many times does this have to be said. I've even linked to the govenment study on this. More air= more fuel being used. Less air = less fuel.
The throttle plate is the largest restriction. If the other logic were true, cars would get their best mileage at wide open throttle.
The fact is, if you want to make your car do a steady 60 MPH down the road it's going to take XX HP to do so. XX HP is achieved by burning a specific amount of air + fuel mixture. FI engines control the AF via O2 sensor feedback when cursing steady-state and in closed-loop mode.
Therefore, if an air filter is more restrictive from being dirty, it's just going to take a hair more throttle to achieve that 60 MPH HP level.
The only time you could probably see a difference on any engine (FI or not) is at WOT because then the reduction of air flow rate (from a dirty filter) would be evident because you can't compensate with any more throttle beyond WOT.
100% agreed.
