Originally Posted By: [RT
ProjUltraZ]calvin < physics -you're also forgetting that fuel maps in the PCM will prob allow the mix to go rich when less air gets in, instead of matching it exactly with less fuel and risking a lean cond. rich = safer for all the manufac
it also depends on how restrictive your stock intake is. on the 4th gen LT1 camaros there were repeated dyno results showing 15-19hp gains w/ the K&N intake. so in my mind the best solution is the K&N intake but using the Amsoil Ea4070 air filter. and yes that also translates to better mpg, but so does grandma driving
Even if this was about intake swaps, which it isn't, hp<>mpg. You might have also noticed that the more HP on tap the lower the MPG, just generally speaking.
Also, where are you getting this about fuel maps running rich?!?!? The only time that happens is at or close to WOT, which again is not really relevant to someone looking to get the best mileage. At all other times an EFI system is at or close to a stoichiometric (perfect) mix or it's broken. The O2 sensor says either "lean" or "rich" and it's up to the ECM to nudge it back the opposite way until the signal changes, repeat. If it runs consistently lean you'll melt valves and pistons, rich and you'll line the cylinder and exhaust with carbon.
Someone please just explain how getting more fuel to the engine gives you better mileage, not power, mileage.
