So, quick question, while shopping in the auto section at WM, i notice they have these k&n "select" dry flow engine air filters. They are double the price of the fram ultra premium about $42 with tax - for the Sonata, but they are NOT oiled. I know not to touch the oiled ones with a 10ft pole, so i picked one up for the Sonata to try and am thinking i'll pick up another one for the Elantra.. But i cant find much info on them. The filter is extremely well built (i would go as far to say over built) you can not see through them like the old style oiled ones - even in direct sunlight, and comes in a high quality sealed box with a k&n decal, and a "STOP DO NOT REPLACE" sticker you put on your air box lid. The k&n select air filter also fits in the air box securely, and the lid locks down very snug, better then the fram i removed. Any one using these select air filters? I bought the one for the sonata because i like to tap it out/clean it every oil change, less waste, and hoping to save a few dollars over the long run, so as long as they filter and will not damage the engines. Plus maybe have 0.01% better throttle response/gas mileage/and power. I know k&n now owns aem, so is this just rebadged aem dry flow? Next time im in wm, i plan to pick one up for the Elantra unless bitog says otherwise, worst case i'll also return the sonata one that i already installed... What are your thoughts on this k&n select dry flow air filter? thanks!!
Info from the wm website:
K&N Select Air Filters have premium dry filter media with durable screen mesh and one-piece frame. These filters install easily and have a service interval up to 50,000 miles that are easy to clean and reuse. These filters come with a 10 year warranty.
- SAVES MONEY: K&N Select washable air filters will save you $200 over 10 years by eliminating the cost of traditional paper filters.
- ENGINEERED POWER: Premium dry filter media produces up to 35% more airflow than disposable paper filters to increase power and acceleration.
- HIGH CAPACITY: Up to 50,000 miles between cleanings. Less work, more play. No oiling needed.
- WORLD CLASS PROTECTION: Pushing the limits of engine protection by protecting your engine from harmful contaminants
- EASY PERFORMANCE UPGRADE: Designed to install easily into your factory air box. One of the quickest and most cost-effective upgrades to your vehicle for quick performance gains.
- RACE TESTED: The Official Air Filter of NASCAR. Trusted on the racetrack—made for your vehicle.
- ECO-FRIENDLY: A K&N Select air filter is washable and reusable. Using washable, reusable products reduces landfill waste.
- PREMIUM QUALITY: Built to last a lifetime and backed by K&N 10-Year Limited Warranty.
