I’ll go along with that.I don't believe it either, with that viscosity index, kv100 and density it can't be 3.2+. 2.7ish will be the ballpark
Mobil Delvac Super FE 10W30 FE-4/SN
40C 64
100C 9.8
Hths 3.1 suggests very little if any VII
I normally would agree with you, but Redline HP 5W-20 has nearly identical specs and an HTHS of 3.1. It's high but not out of the realm of possibility I suppose.I don't believe it either, with that viscosity index, kv100 and density it can't be 3.2+. 2.7ish will be the ballpark
Great oil, but is it Dexos 1 gen 3?I’ll go along with that.
40C 64
100C 9.8
The beauty of HPL’s selection of mPAO as a part of the No VII base oil blend is the ability to create a lightweight motor oil that still has a high HTHS viscosity.I don't believe it either, with that viscosity index, kv100 and density it can't be 3.2+. 2.7ish will be the ballpark
Nope. I just used that oil to illustrate the relationship between KV100C and hths.Great oil, but is it Dexos 1 gen 3?
That’s the specification about which the OP was concerned.
https://bobistheoilguy.com/forums/threads/metallocene-pao-mpao-verses-conventional-paos-cpao.317168/
I’ve reached out to my contacts at HPL to confirm. The initial response was “if it’s on the spec sheet, that’s what was measured,” but I will post the official response once they’ve confirmed.That's not how that works. Density goes down with temperature, viscosity goes down with temperature. The dynamic viscosity of an oil is it's kinematic viscosity multiplied by it's density. The kinematic viscosity of that oil at 150°C is 3.7cSt. Multiplied by it's density we get get 3.19cP but that's not adjusted for the loss in density at 150°C, which can be another 15%. So 2.7 ish is the realistic range. If there were any VII there would be shear thinning on top of that.
IIRC, from my discussion with David, it's the use of the extremely high VI mPAO that changes the behaviour, as this base acts, and is treated, like a VM.That's not how that works. Density goes down with temperature, viscosity goes down with temperature. The dynamic viscosity of an oil is it's kinematic viscosity multiplied by it's density. The kinematic viscosity of that oil at 150°C is 3.7cSt. Multiplied by it's density we get get 3.19cP but that's not adjusted for the loss in density at 150°C, which can be another 15%. So 2.7 ish is the realistic range. If there were any VII there would be shear thinning on top of that.
I would trust the data that they (HPL) published over an extrapolation of how a typical oil performs - that is, taking a 100C value and determining a value at a different temperature.That's not how that works. Density goes down with temperature, viscosity goes down with temperature. The dynamic viscosity of an oil is it's kinematic viscosity multiplied by it's density. The kinematic viscosity of that oil at 150°C is 3.7cSt. Multiplied by it's density we get get 3.19cP but that's not adjusted for the loss in density at 150°C, which can be another 15%. So 2.7 ish is the realistic range. If there were any VII there would be shear thinning on top of that.
Why not ask @High Performance Lubricants as this is the only outlier in the entire table. I trust HPL, but I also trust typing errors can be made.I would trust the data that they (HPL) published over an extrapolation of how a typical oil performs - that is, taking a 100C value and determining a value at a different temperature.
With different base stocks and different additives than a typical oil, the extrapolation simply does not work.
So, the relationship between the two numbers for a typical oil cannot be applied to this oil or this instance.
If you read the thread, you’d see I’ve already reached out to HPL Plant Manager to confirm in writing, but already got the verbal confirmation of “if it’s on the spec sheet, it’s what was measured”.Why not ask @High Performance Lubricants as this is the only outlier in the entire table. I trust HPL, but I also trust typing errors can be made.
One slight modification: if it’s not an oil burner, the Euro oils are a little more robust and there’s no downsides to running it. Keep the 10w30 grade. As an added benefit, one will likely be able to extend the oil changes a little longer because of the chemistry involved.It won't be cold 24/7/365 in OK.
Oklahoma = 10w-30 PCMO.
Did you see the post where he goes to Pagosa Springs, CO and sees -15F?It won't be cold 24/7/365 in OK.
Do you plan for "So maybe -15 degrees, worst case." or what the vehicle will see the majority of the rest of the time?Did you see the post where he goes to Pagosa Springs, CO and sees -15F?
Lovely hot springs, I would just park nearby and soak. The fart smells go away after awhile.Did you see the post where he goes to Pagosa Springs, CO and sees -15F?
The OP specifically expressed a concern about cold starts in Colorado. He even specified the town.Do you plan for "So maybe -15 degrees, worst case." or what the vehicle will see the majority of the rest of the time?
I see others also agree on Oklahoma = 10w-30 PCMO.
