which 5w-30?
Hello everyone from Italy. I'm writing to ask which oils to use and whether they're worth it.
In my Vag 2.0 TDI 150hp, I've always used Mobil 1 ESP 5W-30. Later, I removed the DPF, re-mapped it, and excluded the EGR. I was advised to use a 0W-40, so for the past 5-6 years, I've been using Mobil 1 FS 0W-40.
1) However, I read that Mobil 1 has lost quality in the ESP line... is that true?
2) The new ESP 5W-30 has a poorer base oil. While the 5W-30 ESP Formula P version continues to have the old base oil, with PAO GTL ESTER, etc. Do you confirm?
oldView attachment 289595new formula PView attachment 289596
3) I was thinking of starting to use Ravenol. The tests are all excellent. What's the difference between Ravenol VSW 0W-30 and VMP 5W-30?
4) In my car without a DPF, do you recommend continuing to use 0W-40? Or go back to 0/5W30?
5) I have another VAG, a completely original 2.0 TDI with DPF, AdBlue, etc. I live in an area where summer temperatures reach 40°C (104°F) and winter temperatures reach -5°C (23°F). Do you recommend 0W30 or 5W30?
Thanks everyone
This. https://www.walmart.com/ip/Castrol-...uarts/35931146?classType=REGULAR&from=/search
