which 5w-30?
Hello everyone from Italy. I'm writing to ask which oils to use and whether they're worth it.
In my Vag 2.0 TDI 150hp, I've always used Mobil 1 ESP 5W-30. Later, I removed the DPF, re-mapped it, and excluded the EGR. I was advised to use a 0W-40, so for the past 5-6 years, I've been using Mobil 1 FS 0W-40.
1) However, I read that Mobil 1 has lost quality in the ESP line... is that true?
2) The new ESP 5W-30 has a poorer base oil. While the 5W-30 ESP Formula P version continues to have the old base oil, with PAO GTL ESTER, etc. Do you confirm?
oldView attachment 289595new formula PView attachment 289596
3) I was thinking of starting to use Ravenol. The tests are all excellent. What's the difference between Ravenol VSW 0W-30 and VMP 5W-30?
4) In my car without a DPF, do you recommend continuing to use 0W-40? Or go back to 0/5W30?
5) I have another VAG, a completely original 2.0 TDI with DPF, AdBlue, etc. I live in an area where summer temperatures reach 40°C (104°F) and winter temperatures reach -5°C (23°F). Do you recommend 0W30 or 5W30?
Thanks everyone
This. https://www.walmart.com/ip/Castrol-...uarts/35931146?classType=REGULAR&from=/search
At the end all depend on your needs. I prefer oil with better base quality, cold-short runs performance + right warm protection and more stable properties over mileage, it's 0w range for me vs most 5w. You recon it checking chemical properties and performance over use.
5w is better than a 0w in almost everything. 0w has a lower temp range which most don't need anyway.
In this Engineering Explained video starting at ~8:20, Jason explains, and uses charts to illustrate, why using a oil with a higher winter number (xW) or lower higher number (-xx) than what the manufacturers have specced, are more risky vs using lower winter or higher non-winter viscosities.
Using his example, my Pilot is only specced for 0W-20, but moving to a 0W-30 is still within the normal operating range of the engine, while 5W-30 would introduce a winter range not specced, and potentially, the engine is not designed to operate (I'm not saying it wouldn't be just fine, but potentially outside of spec). Same potential problem should I decide to run 0W-16, or God forbid, 0W-8 to "increase MPGs" <cough-cough> CAFE <cough>-<cough>! In this case, I'd deserve whatever came my way, especially living in central Texas. 😰
It helps to remember that grade is a recommendation not a spec. Engines are designed to tolerate a minimum HT/HS without excessive wear, an oil with a higher one is acceptable and often desirable.
Are they still using that? I thought I read they'd ditched the tungsten additives.
Nice video but light on actual numbers, especially the graph he presents around 10:35.
In the real world, if you aren't using the motor in extreme cold, higher winter grades aren't really "more risky" except in a very pedantic sense. The difference in KV becomes pretty marginal over freezing and essentially no different between say a 0w, 5w, 10w over 20C. In the summer I would not hesitate to run a 10w40 or even 20w50 in a motor "specced" for 0w30 and know plenty of people who do just that in performance applications that prioritize protection over maximum power output.
On the other hand, there are people worried about running the "spec" 0w30 in their motor where the factory racecar version comes filled with 5w30 for endurance stints. It's hard to imagine any of these will make a difference for OP in Italy with his emissions defeated.
But excuse me. So here in Italy, should I use a 1040, which in the summer reaches 40°C?!? Is there a 1040 with a 507 specification? I mean, we're completely out of specification and gradation. Are we sure nothing will happen?! Some people say that 030 is better than 530... but others say the opposite.
Winter rating is irrelevant for you and should be ignored. Just go get any reputable oil with a 507 00 approval if that is what you're looking for.
Also ignore grade. The approval dictates a minimum HT/HS and that's what you'll get.
The grade is mostly irrelevant, you would normally go with approvals but you have deleted your DPF/EGR. I see little reason to limit yourself to 507-appproved oils. You could go with 505 or whatever the older, pre-DPF standard is. Or stick with 507 if that's more available. But I see no reason you couldn't run a 10w40 with 505 approval safely.
I understand for the car without FAP. I was wondering instead about the standard car with FAP and EGR.
Mobil 1 makes 4 oils in the 0 30 5 30 versions. I wanted to know, since they have also changed the formulation, if they are still valid oils or not.
Blenders change the formulations all the time. Some changes are within the interchange rules and don't require recertification, some do. It will say on the container if it has a particular approval or not. Go by that. Or check the VW approval lists.
Again when going by approval ignore the grade, and in your case ignore the winter rating. That won't indicate whether an oil has an approval or not. But it will be listed on the container.
Maybe I didn't explain myself. I don't care what's written on the packaging. I'm interested in knowing what Mobil 1 oils in the 0.30 or 5.30 grades are made of... especially the latest versions of the oils. Do they have PAO? Do they have esters? Or are they all HC? In cars with DPFs, I'll look for the 507 specification... but I'm interested in knowing how these oils are made.
My cousin thinks oil is oil. You guys should talk. I'll pay for lunch as long as it comes with fries. 🍿:ROFLMAO:
Yes I noticed you are focusing on what isn’t important rather than what is.
Base stock composition is way overrated. The approval is what shows demonstrated performance. Good luck on your quest, but you’re circling the wrong water hole. You’re in good company though since there are many threads such as this. Perhaps you’ll find what you seek on some of those if you do a bit of searching.
Just asking, have you been here before asking the same questions?
I'll be the guy and link the multitude of threads we've had on this ESP 0w30 vs 5w30 question recently.
Look at HTHS of a 5w30 vs a 0w30 from the same brand and why 0w oils lost BMW LL01/LL04 spec. They're not as robust.
hths of a 5 vs 0 is most of the times the same.sometimes 0- hths is higher.
0-oils lost their bmw approval not bcs they are not robust but bcs, bmw has stringent limits of oxidation much more than mb or vw does.
new oils either reached bmws oxidation or bmw set new limits so that 0- oils get its approval.
so you are wrong about that,and many users with bmw were still using the same oil although it didnt have the bmw approval on bottle bcs. they knew why.motul xcess 5-40 gen 1 also lost the bmw approval for some time but bmw drivers were still buying that oil.
edyvw has explained that many times,i think he is tired of explaining it ..after so many times, it should be sitcky :)
i am surprised you didnt fall into that explanation post once, its almost in every topic.
in fact there is a lot of talk right now about the new loved bitog oil, m1 esp 0-30 wich doesn't have any bmw approval due to more esters
and thus higher oxidation limits for bmw , but it is suggested that we ,bmw owners can use it safely for a 10000km OCI.
