I was there years ago.Visit siennachat.com for more fun "stories"
Like I said that’s a good one and your stories are getting better and better. What’s the problem?
Nothing lolLike I said that’s a good one and your stories are getting better and better. What’s the problem?
I've been a long term fan of M1 EP. My daily driver is currently at 16k miles and 21 months on a fill of 0w-20 M1 EP. I am experimenting with HPL Premium Plus for now. 0w-30 in the 2016 Honda Accord 2.4 liter and 0w-20 in the 2017 Prius V. More 0w-20 is on deck for my daily driver Ford C-Max Energi PHEV. 0w-16 is on deck for the 2023 Prius.I'm surprised there are not more fans of Mobil 1 EP 0w20.
MaxivanMinivan?![]()
Glenda, I’m not arguing with your take on this, but I’d say their wording may imply that, but in reality I don’t think it does. “Reduce buildup” is intended to imply potential cleaning, but thanks to years of deciphering weasel-speak at work, what I think the actual meaning is, “reduce the rate of buildup” meaning it’s still going to get dirty, just not as fast. Those are two completely different things even though they can both be said in the same way without either being an untruth on its face. I obviously don’t know if my take on this is correct, but absent explicit wording I’m lead to believe their intent is the former phrasing but in actuality it’s the latter reality.I just found this on Mobil 1’s website. A little vague but kinda points to cleaning.
Guess this guy didn't take that advice and his made it to a million and counting on 0w20 lol
Because it is different. A hybrid will spin the ice up to speed before it fires it. Could be spinning 2200 rpm for example before it gets fuel and spark (this has the engine firing with good oil pressure as well)during this time a motor generator is propelling the vehicle and the ice takes over the load or charges it with the. MG with the vehicle having momentum. Conventional start stop stops at idle and fires back up again using the starter and low rpm startup where the combustion speeds the engine up to accelerate when the driver is demanding the vehicle accelerate from a light from a stand atill for example, Not the sameI feel like a hybrid with start/stop is a little different than ICE with start/stop but thas jus me.
Can they not put a small battery there dedicated to just that job of spinning the ICE? That way they could make stop/start that won't hurt the motor.Because it is different. A hybrid will spin the ice up to speed before it fires it. Could be spinning 2200 rpm for example before it gets fuel and spark (this has the engine firing with good oil pressure as well)during this time a motor generator is propelling the vehicle and the ice takes over the load or charges it with the. MG with the vehicle having momentum. Conventional start stop stops at idle and fires back up again using the starter and low rpm startup where the combustion speeds the engine up to accelerate when the driver is demanding the vehicle accelerate from a light from a stand atill for example, Not the same
I have not researched if any are doing this but a system like the mg between the transmission and motor belhousing on upper end Toyota trucks may be able to do this, or may already. I just haven’t looked into it. However, many of the non hybrid stop starts rely on a beefed up starter and eco programming to optimize quick start up so power can be applied by the ice. I have noticed they have improved in drivability from some rentals.Can they not put a small battery there dedicated to just that job of spinning the ICE? That way they could make stop/start that won't hurt the motor.
Thanks for sharing the science. A very neat technology from Toyota
@OVERKILL ’s bespoke blend of HPL SuperCar 0w20 will quite possibly spend its entire life into antiquity as being the most robust “watery” oil ever created for public consumption.I've not been here in a few years and had a stockpile of good ol PP 0w-20, which has run out. So now I haven't caught up on the latest standards and what's good these days. Any suggestions for a good 0w-20 available at normal retailers or amz (not boutique expensive stuff).
[edit: also my car calls for 5w-20 but has 88k now, should I try something a little thicker like 0w-30?]
cheers!
Toyota has two kinds of hybrids, one is purely for power and emissions and one is for fuel economy like in my Sienna. My Sienna engine shuts off at speeds like 75 mph on the highway when I lift my foot off the gas. I cannot believe that new Tacoma hybrid would do that. That hybrid system is different. This is a question that I need to ask next time I see a Tacoma hybrid on the roadI have not researched if any are doing this but a system like the mg between the transmission and motor belhousing on upper end Toyota trucks may be able to do this, or may already. I just haven’t looked into it. However, many of the non hybrid stop starts rely on a beefed up starter and eco programming to optimize quick start up so power can be applied by the ice. I have noticed they have improved in drivability from some rentals.
FYI, M1 is offering $5 back (2 jug max) and Walmart is offering an extra $4 wallyworld bucks/jug. Will bring your jug cost to ~19$.Normally I would go with the Mobil 1 ESP 0W20 but since Pennzoil currently has the rebate for $30 for buying two five gallon jugs of PUP that is what I will be going with. Mobil needs to get back to offering worthwhile promotions, rebates in particular, and I'll go back to using their products.
PUP maybe a better oil in many cases, it flows / pumps nice and quick, Castrol, ep is a real decent oil also, my brother-in-law likes the results of this oil in his car,.Bought some PUP after reading the lakespeed thread but have a stash of castrol EP 229.71. Hindsight I could have went with ESP.
You think Joe Average is going to know the answer to your decoupling question, and discuss the merits of the system with you, while going down the road at 75mph?This is a question that I need to ask next time I see a Tacoma hybrid on the road
