What to look for in VOAs...
Michigan
I'm not quite sure what distinguishes good oils from not-so-good oils by reading the VOA...
I know as much as Moly and ZDDP, but I don't know what either of them do...
Also, can someone please explain to me the difference between all the SM/SL/SJ ratings and what they mean??
Thanks a lot
This page on Blackstone Lab's site will help a bit to explain the elements (although their explanations are more geared toward used oil analysis):
http://www.blackstone-labs.com/gasoline_diesel_report_expl.html
Thanks a lot
Click on the link below for an API Service Category Chart (PDF format) which outlines those ratings:
http://api-ep.api.org/filelibrary/API_MotorOilGuide_2004.pdf
As more and more of the additive package moves to "ashless" components, VOAs are less and less informative. Without insider information, comparing performance specifications or used oil analysis seems to be a better strategy for comparing oils.
Gmorg Is 200% correct anyone that says this or that oil is WEAK or STRONG by using a simple VOA is way wrong.
bruce
Example say you run XYZ oil 5w30 for 5,000 miles and do a used oil analysis and the Fe (iron) is say 100ppm.
Than you run ABC oil 5w30 for 5,000 miles and do a used oil analysis and the Fe (iron) is say 10ppm easy to see which oil is causeing LESS wear in your car.
bruce
