Oil for a 90s JDM Turbo engine
90s car in 40wt?
Maybe a diesel oil since they are already full of zddp and high in detergency, and ready for turbo? I heard 2 stroke motorcycle guys love Rotella T6 so they probably burn pretty clean, maybe that's good for your mod too?
I would run M1 0w40 or Delvac 1300. 0w40 FS has approvals for nearly everything applicable. While Delvac 1300 does not have the same approvals for performance vehicles, its HTHS and 3.6 and 4 for the two different grades, should be plenty to protect you engine. Delvac is a bit cheaper, and hold many other approvals and is SP rated.
O.K. But that bike is 2015 Honda CBR300R which is 4-stroke, not 2-stroke.
Also, there is a lot of incorrect information in the first reply (although it has 20 likes) like—calling phosphorous phosphate and that diesel engines don't have catalytic converters. Both of those are wrong.
Wouldn't M1 0/5-30 ESP be a good fit here?
Just to alleviate some of the rotational drag and let it spin a little more freely?
Totally agree on the 40 weights though.
What does the hivemind here think for use in older technology turbocharged engines from Japan? Engine is a stock internal SR20DET Blacktop but with bolt-ons making 260 whp on 15 PSI. No oil cooler, but has a larger and baffled oil pan. Doesn't see a lot of miles, but often is driven hard and will be seeing track days soon as well. Car has a high flow cat, and doesn't consume oil.
I'll add that I'm currently on HPL Supercar 0w40 but want to explore other options as with shipping I'm looking at $150 for another order from HPL so thinking I'd rather like to spend a bit less and more on driving.
I've been reading lots of threads on here and looking at VOAs and UOAs to get familiar with things and most are all on newer cars or direct injected cars, so I'm less sure about what a desirable add pack is for something a bit more old school and boosted like this, if zinc is still important or less relevant by this point in engine tech vs esters and/or moly. SR20DETs are known for ringland failures and VCT rattles fwiw.
Things to know. 62K miles. Tuned for CA 91 octane. Oil pressure gauge since winter points to about 60 psi fully warmed on highway cruising at 3k RPM and 15 PSI idle. Cold starts have been above 70 PSI and then drop. This has been a cool California winter and spring for the most part, its been driven so far in a lot of 60F-70F ambient and it'll soon be 90-100F just about every day for a while.
Honestly the HPL supercar has seemed great, no concerns at all, sounds and runs great - but at over $150 with shipping right now is pretty gnarly for needing less than 5 quarts.
If its worth mentioning...interested possibly in Nismo/Motul 2193e which seems to be a more streetable (and slightly thicker) 5w40 version of 300V and is about $100 shipped. Amsoil premium protection 10w40 for something more basic, or their Zrod even. I saw on some german forums that Rowe and Ravenol have some high end PAO-based products also in that similar $100 shipped zone or less from some few US sellers.
Mixing Amsoil Signature series 0w40 with a quart of their 5w50 for just a little added temp resilience and increased HTHS doesn't sound silly to me either, unless mixing is considered blasphemy around here.
FSM oil is 5w30 or 10w30, but it's warmer here and car makes a bit more power than stock, which is how i got to the 5w40 10w40 number for summer months. Don't think it's boosted enough or loose enough inside for a 50 weight yet.
I plan on keeping this car for a long time, so I don't mind spending money on a good product, but just not maybe that much haha. Open to other suggestions, but very more interested in learning the whys and what to look for to suit an engine like this.
Thank you! Sorry for long message. Hoping info and thoughts are useful at least.
Mobil 1 0W-40 and call it done. Can we see this car please? I'm a huge Nissan and 90's in general fan🏁🚘
This one is the current "German" Castrol. It's not available at Walmart and you can get online at AutoZone only, and maybe Adv. Auto/O'Reilly.
Castrol EDGE Euro Car 0W-30 (A3/B4)
Here is a thread dedicated to the German Castrol:
https://bobistheoilguy.com/forums/threads/german-castrol-still-available-usa.324054/page-5#post-7548109
Starting to think I didn’t get the ‘good stuff’ or the real OG German Castrol. What I remember buying was castrol edge 0w30 or 40 from a wal mart about ten years ago and the bottle said made in Germany, and it was the only grade maybe at the time that was still made in Germany as the others were Belgium. Something like that. Still was good oil! lol.
What oil did you get?
Btw, the current "German Castrol" is made in the US or Belgium in the Europe. It's not made in Germany anymore. There are plenty of excellent oils for your application in the US and those were already mentioned.
