Quote:
A question that I've always had, is, with the MDS system, is the coolant or oil temp being monitored and the MDS is inhibited until the engine is fully warmed up?
- My point is that during the initial 5-10 minutes of operation, even a 5W-20 will spend several minutes in the 10-25 cSt range, which supposedly is too thick for proper hydraulic operation of the MDS valve train components.
Quote:
Thanks for the reply, Blazer, as I hadn't run across an explantion for the Chrsler MDS system.
So let's carry this thought forward & the next question is:
Is the oil pressure in a Hemi, with the MDS system, measured with a calibrated oriface and sensor to generate a very accurate oil pressure reading?
How else would the system discern between a Castrol Syntec 5W-20 @ 9.0 CSt and Syntec 5W-30 @ 9.7 cSt, both being 100C viscosities?
- I think you can see where I am going with this...
Quote:
I guess Iam the exception to the masses, but I dont have the MDS either. If I did Id run the 5w20. I run Castrol GTX startup 5w30 in the colder months and 10w30 in the hot summer months in Florida. When my Startup runs out Ill switch to Regular GTX. I have a 2006 Hemi but its in a 3/4 ton, I talked with alot of Hemi owners in my area, and most use 10w30 without any problems and no oil useage, the ones I talked to with the newer Hemis using 5w20 were using a about a qt between changes. I have my doubts the Dodge garage is even using 5w20 and not a bulk 5w30. I even called the Dodge hotline and told them I wanted to use a heavier wieght and they said they didnt have a answer but gave me the number of their two largest dealers in Texas, one was Blue bonnet, I think, anyway I called them both and asked them and both replied if you dont have the MDS, it wont hurt a thing, nothing has changed on the hemi since 2002, with the exception of the MDS, and thats what requires the lighter oil, all hemis were switched just to advoid confusion. I just feel better running a oil the has in my mind been the wieght oringinally designed for the engine(oringinal testing when the hemi was first reintroduced) and Not a wieght retro fitted for a fuel saving reason with the MDS in mind.
