Wow, did not realize it was rubber safe. I know it's been around a long time and people seem to love it.Sil Glyde is actually recommend for lubricating rubber parts like door seals and whatnot. I've used it no all manner of things. However I've never used it slide pins. Might give it a try
That's good to know ... thanks. Is the CRC stuff thick enough to last until the next brake job? I've never seen it in person, but in the photos it looks like it might be quite thin?
No one is recommending re-doing the slide pin lubrication or metal-to-metal lube to be done every year or two vs having it last many, many years ? Unless the OP changes brakes every 1-2 years ?
Must be a east coast/rust belt thing. Dried out pins and rusty contact points are a non-issue out here.No one is recommending re-doing the slide pin lubrication or metal-to-metal lube to be done every year or two vs having it last many, many years ? Unless the OP changes brakes every 1-2 years ?
That stuff may be fine on the back of the pads, but it should not be used on any sliding surfaces. It is a rubbery/tacky material.It IS thin; but sticky....it's also bright red. I don't know anything about why the coloration or the viscosity, but I know from experience it will quiet noisy brakes and the quiet will last. If you want to know more, I would suggest finding Trav on the user list and sending him a PM.
M77 seems to be the best lube for that application, followed by anti-seize.
In all honesty, most metal-to-metal lubes become a gritty mess within a few months and may do more harm than good.
Doing that every two years is overkill for a lot of locations. Seeing your location, I can understand that interval. Down here where rust isn't a factor, you can go much longer without having to touch the brakes.
The OP is in Minnesota so it's even worse for him/her.Must be a east coast/rust belt thing. Dried out pins and rusty contact points are a non-issue out here.
The disk brake quiet is for metal to metal so like some pads that don’t come with hardware or don’t have the shims on the back of the pad is when you would use that if you are talking about the red stuff. I wouldn’t use just that as the grease. I use the purple Permatex at work and the Sil-Glyde at home they both work fine for the pins and hardware and stuff I haven’t had any issues.That's good to know ... thanks. Is the CRC stuff thick enough to last until the next brake job? I've never seen it in person, but in the photos it looks like it might be quite thin?
I am using 4 different greases now. M77 under the SS clips. Permatex purple on the pad ears. Sil-glyde on caliper pins and Muscle Grease on the hub so the rotor does not stick the next time I need to remove it.
I use the 3M silicone on enclosed pins and Pastelub (mentioned by Rand above) for everything else mentioned by Donald.
https://goodson.com/products/bpl-2400-pastelub-brake-lubricant Similar to M77. Lifetime tub is cheaper. Thick moly paste that defies water washoff. Made in Switzerland: https://www.igralub.us/
Toyota’s soap based caliper grease. The pink stuff.A bit OT, but what do you recommend for the pins themselves?
That Pastelub looks interesting, and I like the lifetime tub size and cheaper per oz cost vs. M77. Where do you buy Pastelub -- is Goodson the only place?
Which type of Permatex do you recommend?
I've ran into that as well and not even what could be considered "extended intervals". Well, on slide pins, it wasn't an issue but on the back of pads and it turned to a tacky glue-like substance. I had to use a large screwdriver, errrr, I mean pry bar to break it away from the caliper.I know Sil-Glyde is popular, and I use it, too, but I'm keenly aware of its limitations.
In situations where I've used it as a caliper pin lube, it's not good for extended intervals, and worse, it gums up as it ages, having the opposite of the desired effect.
