Originally Posted By: jsecrest
there's nothing wrong with the a/c its blowing cold, im just trying to keep the temp down i do not wont to damage anything. so i will prob replace the water pump and thermostat and if i find one for the right price i will add a an electric fan to help things out. and as for the thermostatic clutch i have no idea, how would i found out?
The first test for the fan clutch is to try to spin the fan* with the everything stone cold. It should move smoothly but with a little resistance and it should stop as soon as you stop pushing on it, not free-wheel by itself. Second, once the truck gets good and hot like you are describing try to spin the fan again*. This time it should be much stiffer than before. If the fan spins freely or doesn't stiffen when everything else is blazing hot then the fan clutch is bad and needs to be replaced.
Besides that, I don't see how a cooler t-stat is going to help here. Keep the stock temp one. If it's bad and not opening then replace it but if it's good then it's doing all it can and the problem is elsewhere in the cooling system. Either the stat isn't opening, the radiator is blocked, the pump vanes are gone or the fan clutch isn't engaging. Check the fan clutch first.
*Hopefully this doesn't need to be said but just in case: DON'T EVEN THINK ABOUT GETTING NEAR THE FAN WHEN THE ENGINE IS RUNNING! Shut the truck down before messing with the fan or its clutch. Those blades will gladly remove any body parts that get close.
