What brakes do you guys use?
I really like my ASP Akebono pads on my daily driver. Great cold performance and they last a long time.
For my fun/weekend cars? EBC Hawk or whatever gives me the best stopping power at the cost of everything else.
I'm not real happy with my Raybestos E3's rotors and pads. They were great for about 20,000 miles and then they developed a slight shudder/pulsing. I had them turned at a local shop and they were fine for another 34,000 or so miles. I'm probably going to go with Power Stop or Centric in a few months. A lot of folks on the Rav4 Forums like the Power Stops.
My go to used to be brakes and rotors from the dealership. They would either make noise after 20k miles or the rotors would have runout problems prematurely. So now I just opt for Duralast Elite pads with Duralast Gold rotors. Warranty is the best way to go about this.
I just received my advics brake pads, first set I’ve ever ordered. The manufacturing is top notch for sure. The fronts are FG, the rears are FF. Not sure about that, but I’m sure it’s fine.
Have Raybestos E3's as well, but on a Tucson. Similar experience with shuddering, but at a much lower mileage of 14,000 km / 8,700 miles. A shame, because I really like the feel of them compared to the OEM stuff. There's still plenty of meat on them still. I can live with it if it doesn't get worse, but if it does I'll have to change them early.
For me, OEM if possible. Else, it’s either Akebono, Bosch or the better AutoZone offerings. I’m liking the Bosch-made Duralast Elites I’ve installed recently.
Just a few friendly suggestions from a Shop owner and mechanic:
1. Lose the Raybestos Element 3's - they used to be my go to pads - loved them but now they are awful. Poor fitment and worst yet poor pad material. I have already seen failures on several cars I did in the past that I good will warrantied they were so bad - my personal vehicles as well experienced cracking pads, pad material coming loose, glazing and noise. I actually would not risk any Raybestos brake parts at this point. There have been several others discuss the lack of quality as well here on BITOG.
great. I have a set of Raybestos EHT pads and rotors for an old GMT400 I need to slap brakes on. Should I just get a different brand of pad? They’re 2022/23 production, made in Mexico I think. I can check when I’m at the house the truck is located at.
Powerstop z23. I love them. Splendid on the street, does not overheat on autocross with plenty of stopping power. Their hybrid track pad is garbage, but the ceramic compound is top notch
For me it's Bosch Quietcast paired with Bosch Quietcast rotors or drums. Great grip, no fade, no squeal, not rotor eaters either. Also like Advics, but their a bit dusty. Also used Wagner Quietstop, but they don't last too long. I have a shelf full of brakes and rotors. Whatever I pull out 1st. Good thing I have a great stock. (Trump tariffs are messing things up big time ) If this keeps up, we'll be turning rotors again. We all know that's a big waste of time. Warp out even faster.
I re-blead my 18 rogue using a scan tool and just got to Cleveland, about 250 miles away. I have 1k on the hc2 rotors and advics pads. Very nice indeed. Not ebc bite, but I can run my finger across the rims and not have it covered in dust.
I've been burned a few too many times with Raybestos Element3 pads, so I'm switching
I did my first job with Bosch Quietcast pads & rotors and I like the fit, feel, and price
Let's see how they age
I tried them when they were all the rage. The rotors were absolute trash and warped within 6 months. The pads had some great bite but the shims and ears corroded before I even got through-half of a winter. When I pulled the pads off to replace them, one had cracked. Bosch is fine but the rotors won’t hold their finish for long. I can get a few years out of ebc before I replace them due to looks, never for vibration. I’m going to start painting the hats and vanes with Por 15 after a year to see how that holds up.
I wasn’t as impressed with the ProActs as I hoped. The included clips needed a lot of manipulation with pliers for everything to seat correctly. Out of the box, they bent inwards too much and kept the pads from sliding. And this was after fully refinishing the surface of the caliper bracket. The pads themselves perform well and are mostly quiet but they make a slight groan type noise when lightly releasing the brakes downhill: maybe this isn’t something people do a lot of but I live in SF. The Hitachi OEM pads Nissan uses were quieter in this regard. Will likely go back to those next time.
Paired them with Advics rotors which perform awesome but have an uncoated unswept area so there is a rust ring. Will look for something with more coverage on the coating next time.
