I have been told it is best to replace ALL the coil packs, (at once,) so that the spark etc stays the same. Sometimes if you replace with new it will make the engine run uneven.I always do those in pairs I’m told with electronic ignition it will fry the computer just replacing one because one new one will be more powerful than the others. I’ve also verified that from experience too. Just a thought maybe replace the rest![]()
Or, expose the weakest coil.
Do it on a Nissan and it throws a code.
Might be more with using different brand/type of coil pack on same engine. Should all be the same....
Sounds good until you look at set of OE cool packs and they want like between $500-$1000 for set of 6 new (insert OE name here)
