much more than 50 bucks....You save money at Walmart, but you pay in other ways. Is your sanity worth $50?
Me! Discount Tire used a metal cup shaped clamp to balance my Volvo wheels. I think the gasket on the cup rim was missing and it cut a circle groove into the face of all four alloy wheels.Has anyone had Walmart, (or any other discount tire places), bugger up nice wheels?
He probably said the numbers were not good.. I did not win the Powerball...Watch the instruction video online for Road Force Balancing and you will always want JUST THAT!
Watch the tech doing it at the shop and you will almost always know that he never saw those instructions.
Last time I got Road Force I asked the Teen Aged tech, “were the numbers good”?…he said,”I don’t know what you are talking about. There are no numbers …I just balance tires”.
About $20 more than I'd been paying at the local Discount Tire. $120 was the last I paid as I recall.How much for that at home service ?
Yes, they have hunter equipment in their van. No on the alignment though.That's cool. Didn't know that was an option. Tire Rack has been my go too, partly because of their excellent website. Do they balance the tires at your house too? Assume no way they would have portable alignment equipment?
Honestly it's about as much as other tire techs. Even if you go to the dealer, the low man on the totem pole does tires.Ask yourself, how much does WM pay tire techs? What kind of people are working for that money?
There are two variables with a road force balance:Watch the instruction video online for Road Force Balancing and you will always want JUST THAT!
But if the guy knows the drill…at least you will know WHICH is at fault.There are two variables with a road force balance:
1. The user knowing how to use it.
2. Trying to optimize a bad tire to a perfect rim, or vice versa. The answer is you can’t. A bad tire on a perfect rim will always have poor results.
It’s not a magic balancer, it’s a diagnostic tool.
Past 30 years I’ve been going to Tire Kingdom and have appointments at 8 AM on weekday.
Im the very first car on lift and out within 45 minutes.
Walmart is less expensive but I have to go out of my way and I refuse to wait a long time to get tires mounted.
Why is it that you have to bad-mouth everyone else with their experiences all the time, but you never post any experiences of your own? A previous poster was right. Take your meds.Here we go again and again.
Why do some continue to post gripe threads about the same experiences every one else has over and over gain?Why is it that you have to bad-mouth everyone else with their experiences all the time, but you never post any experiences of your own? A previous poster was right. Take your meds.
Yes see post #34. Oh I forgot to mention, before they started the job and had my van on the rack, the manager came to me in the waiting area to alert me of a problem I had with my front end. He asked me to go inside with him so he and the tech could show me the problem. Keep in mind the van had passed NYS inspection a few days prior and I checked out the front end during a grease job. I also had the mechanic check it when he did the inspection because I told him I was getting tires and an alignment in a few days. Anyway they pointed to my king pins and informed me my ball joints were bad and needed replacement. I questioned him saying are you sure the ball joints are bad? Yes sir tires and front end work is our specialty, or some other BS reply. Here's where I screwed up. I should have told them not to put tires on it and left. Instead I said do the tires but not the alignment. He questioned why and I said you don't align a front end with bad ball joints, oh and BTW if you're going to try and screw someone at least know the name of the part you're trying to screw the guy for. So never again for them!Has anyone had Walmart, (or any other discount tire places), bugger up nice wheels?
Well it depends, which sort of makes sense when you think about it. These places have hundreds if not thousands of locations.OK, it's pretty much been established over the last 4 pages that Walmart is a roll of the dice, as far as getting new tires installed and balanced properly. So with that said, where is the best outfit to go? Assuming that getting a good job was preferable to chance getting screwed in order to save a few bucks.
Are all of the chain stores like Big-O, Goodyear, Les Schwab, etc. all hit or miss? I have no problem with small local tire joints. But how do you know your're not getting a meth monkey doing the same thing there?
It doesn't require a PHD in mechanical engineering at MIT to replace and balance tires. In short who do, or can you trust?
Sadly around here it might require a PHD. The guy who does my NYS inspection is over double the $80 that WMT is asking for the job, the others are charging $35/wheel and are a crap shoot. In my case it might pay to give WMT a shot. Worst case is I have the credit card to dispute the charge if they screw up the job........ Not exactly how I want to do business but on any given day, any of the shops I reached out to can screw up.It doesn't require a PHD in mechanical engineering at MIT to replace and balance tires. In short who do, or can you trust?
