Cheap OMNI (osp) ?
Lol I think it's dyed so vw can deny a warranty claim on engine issues , otherwise why bother with a dye ?Yes, it's dyed so that someone doesn't accidentally put it into something that calls for something like 504.
It's also dyed to that someone doesn't put non-508 where called 508 is called for.
Further, the dye distinguishes it from other 0w-20's because 508 is very specific 0w-20.
It's dyed so that people who are spec'd 508 get 508.
As has been stated here/elsewhere, it was designed so that you knew visually it was 508 and woudln't accidently use it in a car that called for 502 or 504.Lol I think it's dyed so vw can deny a warranty claim on engine issues , otherwise why bother with a dye ?
Thread locked? They're not going to lock a thread because OP wants to stick to manufacturer's spec, and I'm supporting that.There aren't other 0w20s at a VW dealer. And if it were the other way around, why isn't 504 0w30/5w30 dyed to make sure people don't get 502? Well, because 502 allows for 30 grade oils. No mechanical reason you can't use a 30 grade in a motor spec'd for 502.
OP is worried about nothing and you're going to get another thread locked.
Our local dealer for a long time did not use nor stock 508, they just used a regular 0W20 - can’t remember if Eneos or Idemitsu. Not sure if it’s changed
eh, not getting sucked into this. argue with someone else.Thread locked? They're not going to lock a thread because OP wants to stick to manufacturer's spec, and I'm supporting that.
OP's concern is valid, especially since someone mentioned how their VW dealer was putting in random 0w-20 oil (Post #48)
Yes, 508 is a specific 0w-20.
Not sure why people are recommending going against the spec. Too many assumptions. I'll bet there are properties about 508 spec beyond simply fuel economy for the engines in which it's specified.
Are we to think that if he puts in 508 that there will be problems? Certainly not. Reasons for recommending otherwise? Since I don't see anyone disclaiming their recommendations of "better oil" with OP's warranty concerns, so OP's best interest isn't the consideration. Seems more about reinforcing a consensus-based reality. Kinda why I highlighted my first reply in bold.
Yes. They rely on volume for sufficient cooling. Thicker oil flows less for a given pressure. The turbo, be it bearing or journal, isn't highly loaded. If it was highly loaded then it wouldn't spool quickly. It does get very hot.So you’re saying that a lower film thickness is beneficial to the turbocharger?
That’s an honest question.
The car in question doesn't require a cool down...that's pretty dated advice at this point. They have a pump that circulates coolant after you shut down to handle this.Yes. They rely on volume for sufficient cooling. Thicker oil flows less for a given pressure. The turbo, be it bearing or journal, isn't highly loaded. If it was highly loaded then it wouldn't spool quickly. It does get very hot.
That's why it's recommended to cool down at idle before shutting down after spirited driving. Some vehicles even have a turbo timer function in the tune so that the turbo reaches a safe temperature threshold before oil supply is stopped.
Huh? Dye only in the qt. bottles? Uh, no. My dealer has been using bulk 508 since it started being put in some VW engines and has always been dyed. All drums I've seen there also have VAG part # stickers (and stickers from a mysterious lube company in Beaumont TX.) As said all through this thread, 508.00 spec IS a specifically built 0W-20, DOES require the blue dye as part of that spec, and is dyed to help ensure that it is NOT backward filled into any engines calling for 502/504.They still use the dye , but it comes in qt bottles and I have noticed that randomly some do not have the dye in the oil
Now if you check the oil it will look *dark* with the dye in it ,if it doesn’t have the dye it will certainly look a honey color
0w20 as far as know is not available as bulk oil , but bottled only ,if you get any in bulk I would bet it won't have any dye
Yep. Just replaced the auxiliary coolant pump on the wagon. It stays running for a good 5 minutes after engine shutdown. Turbo "timers" are ancient turbo tech.The car in question doesn't require a cool down...that's pretty dated advice at this point. They have a pump that circulates coolant after you shut down to handle this.
Oil is only a small part of the overall turbo cooling, engine coolant handles a larger portion of cooling duties. Thats why we don't see coked bearings as much as we did when oil was the only turbo cooling medium. And at the temps a turbo bearing sees, the infinitesimal flow difference between a 20wt and a 40wt. won't make a bit of difference in cooling anyway.Yes. They rely on volume for sufficient cooling. Thicker oil flows less for a given pressure. The turbo, be it bearing or journal, isn't highly loaded. If it was highly loaded then it wouldn't spool quickly. It does get very hot.
How does it flow less volume when the oil pump is constant volume?Yes. They rely on volume for sufficient cooling. Thicker oil flows less for a given pressure. The turbo, be it bearing or journal, isn't highly loaded. If it was highly loaded then it wouldn't spool quickly. It does get very hot.
I wonder if some VW dealers are using bulk DuraMAX XLT EURO C5 0W-20?
https://reladyne.com/wp-content/uploads/2025/03/DuraMAX-XLT-0W-20-Euro-PDS-2-5-25.pdf
Has anyone been able to find the Castrol 0W-20 that meets 508.00 available in the US? (not in bulk).here is a picture of fresh 0w30 and 0w20 vw bulk oil from Castrol, you can clearly see the 0w20 has a greenish dye to it.
0w30
0w20
I guess you are randomly responding to me, old timer. Others can ignore this interruption to this absolutely gripping threadCheap OMNI (osp) ?
