In a nutshell simplistic explanation ... a lower viscosity at 40C would give better/easier cold starts if you're in a cold winter climate, and a higher viscosity at 100C would give better engine protection. So if you wanted good cold weather starting, and at the same time good hot engine protection if you're pushing the engine hard, you'd go for a 0W-30 or 0W-40 instead of a 5W-20 as an example.Question about viscosity at 40 and 100, is better to have them lower or higher number?
Sorry but Dude, you smoking something tonight? 40C easier starting? That's got almost nothing to do with starting thickness, it's 104F. OP would be better served to see the viscosity chart for low temperature requirements for labeling. Can't do it myself due to limitations on phone.In a nutshell simplistic explanation ... a lower viscosity at 40C would give better/easier cold starts if you're in a cold winter climate, and a higher viscosity at 100C would give better engine protection. So if you wanted good cold weather starting, and at the same time good hot engine protection if you're pushing the engine hard, you'd go for a 0W-30 or 0W-40 instead of a 5W-20 as an example.
40C and 100C is the temperature of the oil of course ... just to be sure you get that part.
You might want to try grasping the words a bit better before starting off a reply like that ... I was talking about comparing different viscosities to each other in a simplied matter. Oils with a lower KV40 will also be thinner at lower temps than oil with a higher KV40. and therefore will provide better cold starting in cold conditions. And oils with a higher KV100 will provide better protection when the oil is at 200+ F. It's a well know fact of tribology that thicker viscosity provides more MOFT which gives more protection from moving parts contacting each other and causing metal-on-metal wear. You've been here since 2005 and should have read that about 1000 times over the years.Sorry but Dude, you smoking something tonight? 40C easier starting? That's got almost nothing to do with starting thickness, it's 104F. OP would be better served to see the viscosity chart for low temperature requirements for labeling. Can't do it myself due to limitations on phone.
edit: ZeeOSix, I see free2d's interpretation of your post now, and if that is what you intended I apologize for jumping all over your post earlier in this one.
All viscosity oils will flow well at 100C (212F) when the oil is at full operating temperature. However, a 40 weight is going to give more oil film thickness between moving parts than a thinner oil at 100C, and help better prevent any metal-to-metal contact and wear.As for viscosity@100, well I don’t know, higher or lower is better? Lower so that at 100C will flow better all over the engine and not “heavy”? Or higher at high temperature so it holds viscosity.
What viscosity does the owner's manual call out? If it's a 5W-20, I'd just go with 5W-30.I am looking at 5W40 grade oil for my old Honda Accord 2005. Nothing fancy.
There is a difference between oil "film strength" and oil "film thickness". Sounds like you're talking about MOFT ... Ie, film thickness, not film strength. And yes, they are both important.Or, interpreting your post differently, the debate on this site -- as to whether thicker or thinner oil is better -- is an epic and continuing one. Some prefer a thicker oil for a stronger film strength since it's a layer of oil that separates moving metal parts. Some prefer thinner to increase flow rate, choosing to rely on additives to protect the engine if the boundary layer goes away. Additives have improved greatly in the last several years, which fuels the discussion.
Engines can have more wear over the long run from using thinner oils, and never have an "engine failure". Those two things are way far apart from each other. As they say, most people don't keep vehicles forever, so what the hay if they wear out a bit more from thinner oil use while they own them, lol.Both schools of thought have their merits, and as stated before the ongoing debate between the schools of thought has been, and likely will continue to be, epic. There's no single easy answer - millions of vehicles using 20 grade oils (of all variance of thickness within the grade) have not had engine failures.
Yes, and hence why I like relying on viscosity as the first line of defense to protect the engine. The AW/AF additives that provide the "film strength" can then kick in IF the viscosity doesn't prevent the metal-to-metal contact between moving part.Conversely, many manufacturers recommend a 20 grade oil but state in the owner's manual something to the effect that a thicker oil is required under certain conditions. Plus, Ford has gone back to a 30 for their truck V8 engines from their earlier recommendation of a 20.
Well, the manual gives 5W-40 as an option, so should be no issues at all using it.Manual stated 5W30, 5W40, 10W30.
Using 5W30 now, thinking oil change to 5W40 since old car.
There wouldn’t be any issues even if the owners manual didn’t “allow” (recommend) it. There is no conceivable instance where at 40-grade would damage his engine.Well, the manual gives 5W-40 as an option, so should be no issues at all using it.
Where do you drive this car ?Manual stated 5W30, 5W40, 10W30.
Don't let 40C hang you up. Speaking of the viscosity vs temperature chart, go use Widman's viscosity vs temperature calculator and look at the plot curves of different oil's using their KV40 and KV100 data points and you'll see what I mean.
Anyway ... apology accepted.
You're 100% correct; de-escalating.
Obviously, but given the noobness of the situation, if the manual says 5W-40 is fine, then it just backs up the fact that it won't "hurt" anything.There wouldn’t be any issues even if the owners manual didn’t “allow” (recommend) it. There is no conceivable instance where at 40-grade would damage his engine.
I wasn't trying to define the definition of "cold start". All I was saying (and you can verify it with the viscosity calculator), is that if "Oil A" is thinner at 40C than "Oil B", then "Oil A" also going to also be thinner at any temperature below 40C and therefore be better for cold starting. I was trying to put it in simple terms that someone without much grasp of viscosity vs temperature seems to have, and all he's looking at is viscosity numbers of different oils at 40C and 100C.I have read it more than 1000 times, no need to be condescending. You and I are in agreement on oil thickness.
I've used the Widman calculator numerous times. Perhaps our definition of "cold start" is different. I was simply (and indirectly) pointing out that a 40C/104F start is very different than a -30C/-22F start, and that since OP had questions that a chart might have been more helpful to illustrate your point.
