Oil Viscosity Basics: 0w40 vs 5w30 Cold Start
So I have a question about how viscosities correlate to temperature ranges in real world use. I recently read that while a 0w40 meets pumpability requirements at the -35C to -40C range that outperform a 5w30, the 5w30 often has lower viscosity around 0C than the 0w40. I had thought that a 0W oil would outperform a 5w oil for cold flow at pretty much all temperatures below 40C. If that is not the case, is the common BITOG member recommendation of Mobil 1 0w40 in place of a 5w30 in many gasoline truck engines actually causing more engine wear on cold starts?
One of the most common misconceptions on here.
Also the misconception that the winter rating is about wear. It’s not.
