Originally Posted By: vinu_neuro
The viscosity calculators out there are for kinematic viscosities, cst. Pumping viscosity cP which afaik is absolute/dynamic viscosity. I don't understand how it's possible for some oils to have a lower kinematic viscosity than others at low temps, but at the same time have a higher pumping visc. If someone would like to take a stab that too, I'd appreciate it.
Also what exactly is pumping viscosity related to in terms of protection, ie. is it only relevant until the point an engine reaches consistent oil pressure (start-up) or beyond that too?
You're right, kinematic viscosity graphs are only half way reliable down to about -15C for 0W-XX oils ans less so for heavier grades.
A 0W-XX must have a pumping viscosity no greater than 60,000 cP
at -40 degrees. That's mighty thick oil and not surprisingly why MRV is called borderline pumping. Obviously you want the oil to be as light as possible as even the lightest 0W-XX oil you can buy, Mobil 1 0W-20, is still mighty thick with a MRV of 10,400cP.
How quickly the oil pressure comes up I would imagine is an engine specific question, but in theory if it's a 0W-XX oil in the sump, it should safely pump at -40.
