Viscosities of various 0W-20 and 5W-20 oils
Midwest
I went through every major brand's Product Data Sheet (PDS) to document viscosities. The ones in bold do not have PDS that I could find, so I listed viscosities from VOAs for those. Sorted from high to low.
0W20 and 5W20 Oils
KV100
Mobil 1 EP 5W20​
9.00​
Mobil 1 Truck & SUV 5W20​
8.90​
Castrol Edge EP 5W20​
8.90​
Pennzoil SB HM 5W20​
8.90​
Mobil 1 AFE 0W20​
8.80​
Mobil 1 HM 0W20​
8.80​
Castrol Edge HM 0W20​
8.80​
Pennzoil Ultra Platinum 0W20​
8.80​
Pennzoil Ultra Platinum 5W20​
8.80​
Valvoline HM 150 5W20​
8.80​
Valvoline HM 75 5W20​
8.80​
Mobil 1 EP HM 0W20​
8.70​
Mobil 1 EP HM 5W20​
8.70​
Castrol Edge EP 0W20​
8.70​
Quaker State SB HM 5W20​
8.69​
Pennzoil SB 5W20​
8.63​
Mobil 1 EP 0W20​
8.60​
Mobil 1 5W20​
8.60​
Mobil 1 HM 5W20​
8.60​
Mobil 1 Truck & SUV 0W20​
8.60​
Castrol GTX FS 0W20​
8.60​
Castrol GTX FS 5W20​
8.60​
Castrol GTX Ultraclean 5W20​
8.60​
Pennzoil Platinum 0W20​
8.60​
Pennzoil Platinum 5W20​
8.60​
Quaker State SB 5W20​
8.55​
Quaker State FS HM 0W20​
8.51​
Mobil FS 0W20​
8.50​
Pennzoil Platinum HM 0W20​
8.50​
Valvoline HM 75 0W20​
8.50​
Valvoline DP 5W20​
8.50​
Quaker State FS HM 5W20​
8.42​
Quaker State FS 5W20​
8.41​
Mobil Super 0W20​
8.40​
Mobil FS 5W20​
8.40​
Castrol GTX Magnatec 5W20​
8.40​
Valvoline EP 0W20​
8.40​
Valvoline AFS 0W20​
8.40​
Valvoline FS HM 0W20​
8.40​
Supertech FS HM 5W20​
8.38
Supertech Advanced FS 0W20​
8.34
Quaker State FS 0W20​
8.33​
Mobil Super 5W20​
8.30​
Mobil FS HM 0W20​
8.30​
Mobil FS HM 5W20​
8.30​
Castrol GTX Magnatec 0W20​
8.30​
Pennzoil Platinum HM 5W20​
8.30​
Valvoline EP 5W20​
8.30​
Castrol GTX Ultraclean 0W20​
8.28​
Castrol Edge 5W20​
8.20​
Castrol Edge HM 5W20​
8.20​
Valvoline FS HM 5W20​
8.20​
Supertech Advanced FS 5W20​
8.20
Castrol Edge 0W20​
8.18​
Supertech FS HM 0W20​
8.12
Valvoline AFS 5W20​
8.00​
Mobil 1 ESP 0W20​
7.90​
Supertech FS 0W20​
7.89
Castrol GTX HM 5W20​
PDS not avail​
Here is the same chart, sorted by grade, HM, then viscosity.
0W20 and 5W20 Oils
HM
Grade
KV100
Mobil 1 HM 0W20​
HM​
0W20​
8.80​
HM​
0W20​
8.80​
Mobil 1 EP HM 0W20​
HM​
0W20​
8.70​
HM​
0W20​
8.51​
HM​
0W20​
8.50​
HM​
0W20​
8.50​
HM​
0W20​
8.40​
Mobil FS HM 0W20​
HM​
0W20​
8.30​
HM​
0W20​
8.12
Mobil 1 AFE 0W20​
0W20​
8.80​
0W20​
8.80​
0W20​
8.70​
Mobil 1 EP 0W20​
0W20​
8.60​
0W20​
8.60​
0W20​
8.60​
0W20​
8.60​
Mobil FS 0W20​
0W20​
8.50​
Mobil Super 0W20​
0W20​
8.40​
Valvoline EP 0W20​
0W20​
8.40​
Valvoline AFS 0W20​
0W20​
8.40​
0W20​
8.34
0W20​
8.33​
0W20​
8.30​
0W20​
8.28​
Castrol Edge 0W20​
0W20​
8.18​
Mobil 1 ESP 0W20​
0W20​
7.90​
Supertech FS 0W20​
0W20​
7.89
HM​
5W20​
PDS not avail​
HM​
5W20​
8.90​
HM​
5W20​
8.80​
HM​
5W20​
8.80​
Mobil 1 EP HM 5W20​
HM​
5W20​
8.70​
HM​
5W20​
8.69​
Mobil 1 HM 5W20​
HM​
5W20​
8.60​
HM​
5W20​
8.42​
HM​
5W20​
8.38
Mobil FS HM 5W20​
HM​
5W20​
8.30​
HM​
5W20​
8.30​
HM​
5W20​
8.20​
HM​
5W20​
8.20​
Mobil 1 EP 5W20​
5W20​
9.00​
5W20​
8.90​
5W20​
8.90​
5W20​
8.80​
Pennzoil SB 5W20​
5W20​
8.63​
Mobil 1 5W20​
5W20​
8.60​
5W20​
8.60​
5W20​
8.60​
5W20​
8.60​
5W20​
8.55​
Valvoline DP 5W20​
5W20​
8.50​
5W20​
8.41​
Mobil FS 5W20​
5W20​
8.40​
5W20​
8.40​
Mobil Super 5W20​
5W20​
8.30​
Valvoline EP 5W20​
5W20​
8.30​
Castrol Edge 5W20​
5W20​
8.20​
5W20​
8.20
Valvoline AFS 5W20​
5W20​
8.00​
Take a look at viscosity index number next time. And volatility, which will affect viscosity over time.
I'm surprised to see Castrol Edge and Castrol Edge EP in both OW-20 and 5W-20 grades at the low end.
8.20 and 8.18
I got a tiny Ford Ecosport with 1.0L EcoBoost. I drive above average mileage and do use this vehicle for light towing purposes as it is rated for it.
Ford specs 5W-20 oils and I've been using a full synthetic OW-20 in all of my Ford vehicles. I switched from Mobil1 to Castrol Edge oil after learning that Ford worked with Castrol directly in developing a European spec oil for this 1.0L EB before it even went into production.
I thought it was all a marketing gimmick but I'm liking the Mobil 1 Truck and SUV oil especially since it seems it's on the higher end of all those viscosity numbers since I prefer to use OW-20 over 5W-20 oil.
One of the selling points of the Mobil Truck and SUV oil is it has 10% more detergents or whatever to clean and keep deposits from building up. That's got be good for those tiny turbocharger bearings.
Oil noob here, what are we suppose to learn from this chart
There is a range of acceptable viscosities within each grade. If, for example, your car is known to fuel dilute and you want to try to mitigate that while continuing to use the grade your vehicle recommends, you might pick an oil with a thicker viscosity to give it more chance of staying in grade by the time the oil change interval is complete. If your car is known to keep its oil's viscosity while in use and you want to maximize fuel economy, you might pick an oil on the thinner end of the spectrum.
Thank you! So the higher number here means that it's a thicker viscosity
Some of these may have changed since last year when you originally wrote this up. One is particular that I noticed is the M1 EP 0W20 / 5W20 since I use that.
M1 EP 0W20 = 8.8
M1 EP 5W20 = 8
OW20 is a little thicker than the 5W20.
I'm not maintaining this list anymore. But it's good to post new oils here so they are available for those who are interested. I'm taking care of the VOA Database now, which includes measured viscosity (but not manufacturer spec).
