Betting it’s that - and it’s a diesel LT - not a car …
I’m betting it’s BMW gasoline… and a car since he specified. Last bet of the year!The normal drain interval on my car is 22k miles....
Giulietta diesel ? So OEM is 22k … ?His signature says he drives an Alfa Romeo.
Still waiting for you to back that up with something …Or get HPL for $11.69/quart and a bottle of their engine cleaner if you wish and be light years ahead of that Valvoline gimmicky garbage.
the first EPR flush was at 165k and that oil came out nasty and darker than diesel oil. i do 20 minutes at 2k when i flush.Epr is some strong stuff.
I'm surprised it did not work for your consumption
Can the same be said about HPL and their oils? I don’t think so but what’s the difference?Although I’m a Valvoline fan, this seems like BS. If a motor oil can clean pistons as they’ve shown in the advertisement, that engine is getting a tremendous amount of oil past the piston rings. If someone does use it, keep a close eye on your oil level. I’ll just keep using the plain Valvoline Advanced. This has my radar up. When kooky things start happening in an oil company they might be grasping at straws to find a profit.
Don’t know anything about HPL. Valvoline has been used since the early 1920s.Can the same be said about HPL and their oils? I don’t think so but what’s the difference?
What oil cert is recommended for your car?
Stress is good. What does the oil cost ?U guys are making me nervous like this new oil needs to prove itself. Maybe I should take it back and get something that’s been around awhile. I think they probably just tweaked the EP package aliitle and gave it a new name.
Thats interesting because a lot of people on here, myself included, has used or is currently using HPL oil that have had great results cleaning the ring lands with no reports of having tremendous oil consumption due to the cleaning that I’m aware of. Am I mistaken to believe that stuck rings actually increases oil consumption because of carbon build-up and that cleaning lessens it?That’s a stretch. You must not have enough technical ability to understand how that oil could clean ring lands. That oil is also making it into the combustion chamber and the engine is burning that oil.
Don't be condescending, you don't know me.That’s a stretch. You must not have enough technical ability to understand how that oil could clean ring lands. That oil is also making it into the combustion chamber and the engine is burning that oil.
I guess piston skirts are now located above the ring pack.
What are you going on about?I guess piston skirts are now located above the ring pack.
Understood.
You get what you give Hoss.Don't be condescending, you don't know me.
I've already commented about ring cleaning and/or stuck rings earlier in this thread or the other Valvoline R&P thread. Try harder. Regardless of what oil is being used, it would get ingested under vacuum if the rings are stuck from carbon. Your comment suggested people would have to check because they were using restore, rather than it being a normal practice for an oil burner.
Your post also sounded like a conspiracy theory that Valvoline is trying to dupe people. They used a sequence test and the piston photos are the actual results of testing. Some base oils are known to clean carbon (ANs, certain esters), and Valvoline has patents on carbon cleaning oil formulas. They have the knowledge (premium blue restore, patents, formula 1) to formulate a complete, high performing oil that prevents and even cleans deposits.
No reason to doubt the claims of carbon removal in 4 service intervals
