Valvoline Restore & Protect 5w-30 (Gonna Take a Chance)
Arrived - with oil filter bundle - did not need an oil filter but they cut my air filter price by that amount …
View attachment 195240View attachment 195241
The deal options 5 singles - so I went back to facilitate an 8 quart engine change … and a filter …
Interesting this arrived shortly after Valvoline’s acquisition by Aramco. Maybe it has a secret sauce…
Is this like a rebranded gasoline cousin to the Valvoline Premium Blue Restore that was co developed with Cummins?
"This oil was co-developed by Valvoline and Cummins to clean the piston rings on ISX15 engines that were experiencing oil consumption. Supposedly this oil contains a significant percentage of a high-solvency Group V ester basestock"
I wonder 🤔
The interesting parameter to look at would be the oxidation level. Other than that I don't think the traditional $30 VOA approach will reveal much but we'll see ...
Agree, but that's also assuming they're using some ester to clean. It could be something new.
I wonder 🤔
No, apparently, it's nothing like it. PBR though did use Group V (ester) for the cleaning.
I see R&P gives 8x wear protection whereas Extended Protection gave 10x. Everything comes at a cost I guess. 🤷‍♂️
I have no idea what any of that means other than marketing but Valvoline is not the only one using that lingo, Castrol does too.
Don't be condescending, you don't know me.
I've already commented about ring cleaning and/or stuck rings earlier in this thread or the other Valvoline R&P thread. Try harder. Regardless of what oil is being used, it would get ingested under vacuum if the rings are stuck from carbon. Your comment suggested people would have to check because they were using restore, rather than it being a normal practice for an oil burner.
Your post also sounded like a conspiracy theory that Valvoline is trying to dupe people. They used a sequence test and the piston photos are the actual results of testing. Some base oils are known to clean carbon (ANs, certain esters), and Valvoline has patents on carbon cleaning oil formulas. They have the knowledge (premium blue restore, patents, formula 1) to formulate a complete, high performing oil that prevents and even cleans deposits.
No reason to doubt the claims of carbon removal in 4 service intervals
Valvoline is off the shelf additives blended into purchased base oils. They do not innovate in-house. They have a massive advertising budget but they are not some cutting edge formulators themselves.
