It's a slow cleaner although some will notice changes pretty quickly. It could even take longer than 4 OCI and really would ideally work best if continuously used.
Seems to be the marketing fail of VRP. Nobody seems to want to use VRP after the four oil changes.![]()
What oil were you using that caused the problem in the first place?I'll be using it in my Audi Q7 with the supercharged 3.0 and my 5.3 Chevrolet 1500 past the 4 oil changes. Common sense with the great used oil sampling and low wear metals would say, why go back to oils that make the piston deposits and ugly engine internals again. I see no reason to go back to regular/other oils that make the piston deposits and carbon up the oil control rings ever again.
I think once the cleaning is done, some (probably only small % of mostly BITOG folks) go back to something more robust like a Euro oil etc. If you have a domestic or even Japanese car that doesn't call for anything about a SP/GF-7 oil I'd likely stay with VRP. I'm curious if this tech makes it into other grades eventually.Seems to be the marketing fail of VRP. Nobody seems to want to use VRP after the four oil changes.![]()
I wonder if it already is in there…….……… I'm curious if this tech makes it into other grades eventually.
I was a bit excited when I made this post as this was something I managed to fix with no suggestions or feedback from the mechanics I contacted about this problem. Whenever I brought it up to a mechanic, I usually got a blank stare or suggestions like "time to get a new car", "new engine", "used engine" etc. For some reason they did not suggest an engine flush at any place that I contacted or even something like HPL. Maybe that's just the state of mechanics...That was a big first post, you "really" have a liking for the Valvoline Restore & Protect? Maybe I should try this magic soon.
I didn’t even see an improvement until the 3rd oci(for oil consumption) 4 oci’s minimum are needed IMO.
Well if you buy enough HPL that will do it too. I’m still on fence about trying R&P in my 02’ Dakota.Having very basic approvals, after certain point it will start cleaning your wallet.![]()
I ran 5) 3,000 oil changes during the winter to make sure my ring land were fully clean. My massive fuel dilution problem was cleaned up by using Redline Performance 5W-30 Euro and use of HPL EC 30 &40. I just used VR&P since it was designed to clean ring lands and I am too cheap to use $80 HPL and dump at 3,000. My hypothesis on my car was my top 2 rings where jammed and I had massive fuel dilution as high as 1.5qt in 3,000 miles. Redline fixed it and I have no idea when and what oil fully cleaned my Hyundai's rings. They are one of the leading cars if not the worst manufacture along with Kia to have carbon jammed rings. I did feel my car "ran better" after a 3) 3,000 dumps. I know it idles better for sure. Could be placebo though who knows. All I know is VR&P will be in my car this winter. As my summer oil is 5W-40 when my turbo car gets thrashed the most at higher temps.
I bought my car new and my engine was spotless through it's life, as I was running all the high end oils and boutique oils at 3,000 mile dump intervals. Amsoil SS, Mobil1 Extended, Mobil1 ESP the last 1.5 to 2 years of it's life before the Redline Performance's ester cleaning that release what I think are my top two rings that were jammed. I just own a Hyundai, and that means your car is automatically in rough service mode as it's default. It is also a tuner car and gets thrashed daily. Also my tuner is a known tuner in the industry and he does not tune rich, he actually tunes on the lean side.Do you folks even check first if your motor is sludged up or not before using R&P? Correct me if I am wrong, but burning oil is not the only sign of a dirty engine.
