Those comments are of little/no value anyway.
Aren’t they the experts ?
Not really. They can run the analysis, but their comments are generic. They are not tribologists.Aren’t they the experts ?
Exactly (color and font size changed by me to emphasize what i'm agreeing with)Not high enough and the moly offsets LSPI issues.
This oil should not be viewed as something new and groundbreaking. It's simply Valvoline's attempt at addressing the DIY/Extended drain oils from XOM/BP. I'm sure it is very good, as are the others.
thanks for the voa, the zinc, phosphorous, and calcium are fairly high for a gasoline oil in the lspi era.
Not directly. they're being very careful to not state but very heavily imply. this is what they say
they're basically trying to say its extended drain.
- Full synthetic formula that is 10X stronger against oil breakdown vs. industry standards as tested in the industry Sequence IIIHA test
- Specially formulated with Dual Defense Additive Technology, combining an innovative additive booster and a fortified detergent system
They have value to me.Those comments are of little/no value anyway.
I actually like the idea of an extended performance oil over extended drain. My main concern is maximum engine protection, oil is cheap, engines aren't, and I'm just gonna dump it at 5k or before anyways.I don't think this is an extended drain oil. Valvoline has never advertised extended drains.
Have we seen a VOA or UOA of VAFS SP. I'm curious how much Moly is in it and if they're still using titanium.At least with this oil you can see why it's a little more expensive than the VAFS. The extra Moly is definately worth the extra $4/jug if Moly is important to you. I will try the 5W20 or 5W30 next. I'm intrigued.
Thanks for sharing, OP.
Here’s the new EP of theirs: https://bobistheoilguy.com/forums/threads/valvoline-extended-performance-0w20-voa.341710/Have we seen a VOA or UOA of VAFS SP. I'm curious how much Moly is in it and if they're still using titanium.
Lololololyou do realize that you linked the same thread we are already in right?
Here is a recent analysis of their regular full syn in 5w20. Pretty good dose of moly in it as well. Not sure what kind of moly they are using tho: https://pqia.org/valvoline-full-synthetic-advanced-sae-5w-20-motor-oil/I wonder if all weights of this oil have that same high moly add pack?
