Originally Posted By: SatinSilver
Any thoughts on the Rotella T6 you used initially? I see you went away from it later on. Thank you.
The engine did not like T6 0W-40 as the overnight temperatures dropped into the 30-40F range. I was getting P0016 every morning, even warming the engine up for a few minutes. And throttle response was noticeably sluggish, like driving uphill, until the engine was fully up to operating temp for quite a few miles and the oil was warmed up. My theory on the P0016 frequency increase was that the thicker cold viscosity was delaying pressurization of the #2 chain tensioners, which aren't a ratchet design like the #1 tensioner. All three chains in this engine are elongated from prior oil change neglect.
Changing to Amsoil 0w30 brought P0016 back under control, and throttle response was much improved at cold temps.
