vacuum cleaner recommendation
North Carolina
I need a good vacuum. We have a hoover pet, bagged vacuum that just does not seem to work well. We have carpet and hard floors. I'd prefer a unit that has a hepa bag.
For those with pets , any recommedations? We have dogs.
My next vacuum cleaner is going to be a Miele. Made in Germany and over-engineered for sure. Expensive, but should be the last you ever have to buy.
Miele, - all my miele stuff has been top flight.
Id rather have a bottom of the line miele product than about anyone else's top end.
UD
I have a Maine Coon. I use the iLife V3S on my hardwoods, and V4s on my carpeted. They work amazingly well, and I have not had to actually use my "real" vac in over 2 years except on stairs. Just my .02
*I also have a German Shepherd/Collie mix that is allowed inside from time to time, as well. Handles that, too.
Eureka Mighty Mite
Bought ours about 4 years ago. Still has enough power to pull the carpet off the floor.
Very simple design, focused on power and reliability.
Others seem to love it too!
(now it's listed as an "Amazon Choice")
I have some Dyson ball model that was somewhere ~$300 at Costco. Knowing what I know now, I wouldn't buy another.
The suction is great, and the best part of the vacuum.
The build quality is ok, but probably not commensurate with the price, at least from my perspective that it replaced a Sharp vacuum from the 90s, and I don't know whether the overall standards have risen, or more likely, fallen.
The thing that drives me nuts about it, and am often reminded of during use, is that the mechanical engineering is poor. That's something Joe Public may not notice, but for the folks here surely would.
Specifically, the backbone of the vacuum, which has to bear the bending and torsional forces during use, isn't rigid enough, and the design is highly reliant on the wand being locked into place to provide a lot of that rigidity, so it's one mode or the other.
There are two handles on the vacuum. The top handle where it is held during use, and another hoop that is part of the canister, which must be used to pick up and transport it. If it is lifted using the top handle, which to me is not an unreasonable expectation, what happens is that the backbone bends, and the flimsy little latch that secures the top of the canister unlatches on its own from the spine, due to it bending from poor rigidity. Without either the canister or wand locked into place, it does a good impression of a wet noodle.
Additionally, the hose for the wand is very stiff, and hasn't loosened up appreciably even after years of use. That, combined with the relatively small footprint, often results in the whole vacuum being dragged to the location where you're standing when the wand is used. That might be cute with a pet, but is not desirable when you expect the vacuum to remain stationary when the wand is used. The length of the rigid portion of the wand can also present clearance problems in tight spaces.
The swiveling nature of the ball is good on carpet, but not so great on floors, requiring more force to be exerted to get it to turn. And the rigid skirt around the suction portal tends to push debris around on floors, rather than allowing it to be captured.
In short, don't believe the hype.
I guess it's a good thing that Dyson's grand plan to make a car failed, because if that's that type of engineering that went into it, then it would have been a questionable product.
I bought a Shark for mom, replacing the old Riccar. First day of use had to empty the canister numerous times. Apparently the old Riccar had overstayed its welcome
Goodhousekeeping rates vacuums. We have a Kenmore Intuition upright with HEPA bag and HEPA exhaust filter for our pets and it works well. My neighbor had a Miele and she hated it due to the weight.
We had a Dyson which worked well but was very heavy and awkward to move while vacuuming. Bought a Shark on a few personal recommendations and we think it cleans as well as the Dyson at a fraction of the weight.
We had a dyson that lasted for yrs and then got a shark. Wife says it's the best vac she's ever had and was a fraction of the dyson.
