household vacuum recommendations
Let's see, over the past 30 some odd years we've had Kirby, Hoover, Filter Queen, Rainbow, Dyson, Oreck, Riccar and the only brands that I would recommend are German: Miele & Sebo.
We would have saved thousands of dollars if we went with Miele or Sebo initially.
Oh and a Roomba doing its thing in-between keeps your carpets and floors nice and clean.
I sorta went through this process over the last couple of weeks. A dumb relative somehow broke my Electrolux canister vacuum (an old style "real" Electrolux, not the newer Eureka/Electrolux), which I've been using 4-5x/week for the last 13 years. It lost power to the nozzle, so the brush roll wouldn't turn. Did everything I was capable of to diagnose it, couldn't figure it out, so dropped it off at the vacuum store. While waiting for them to call back I researched new vacuums.
The $250-300 price range is going to limit you to the basic consumer brands - no Miele, Sebo, Riccar, etc. IMHO a canister that uses bags is the way to go, more versatile, easier to use, suitable for stairs, etc. I'd decided, if I was going to go for a low-cost replacement, to get this Panasonic for $300, delivered from Amazon.
Had I decided to go with something pricier (which I probably would have, I think vacuums are something where the adage that you get what you pay for rings true) I probably would have gotten a $500 Miele Delphi, maybe splurged with a Titan, Topaz or Sebo K3. These range from $600-750, price increasing with the number of attachments and filtering.
In the end, the store called and said they could replace the Electrolux's internal wiring and have it back in business for $200. I elected to go that route, figure I'll get many more good years out of it and it's certainly nicer than anything else I could get for $200.
jeff
What if motor noise is a decision criterion? I have all hardwood floors and our Shark upright is loud. Suggestions?
Noise tends to be inversely proportional to price. I was amazed at how quiet the Sebo K3 was when the guy in the store showed it to me. Sebo makes a K2 ($400 delivered from Amazon) which has a bare floor nozzle instead of a power nozzle, and Miele's range includes similar options ($300 from Amazon). It might seem like a lot for a "basic" vacuum but these things beat the pants of lesser models.
jeff
Jeff, thanks for the web links. The Miele S2121 Olympus canister looks good. I'm not buying yet, but good to know for when I am.
I just read through this thread. I see there's very little love for the Bissel's. That's a shame.
While I can imagine they can't compare with the real premium machines (brands I've never heard of ... but I trust they are the real deal, unlike the fragile, over-hyped Dysons) I find Bissels to be VERY cost effective and nearly impossible to kill without physically breaking components.
Over the past 4-5 years, I have pulled several vacuums out of a local dumpster. Most were Bissels and the ones that had most or all of their parts were simple fixes. Usually they just needed a thorough cleaning and they were good as new. I also fixed/cleaned one Eureka and a Hoover ... but just don't care for the way those machines were put together.
I would give most of them away to friends and family. One I brought to work (a Bissel Momentum) and used it there for about a year before I gave it to an employee to take home.
I bought a remanufactured Bissel Healthy Home a few years ago. While it seems to clean well, it is very heavy, has no useful handle for lifting and the worst aspect: emptying the large dirt-cup (which contains a complicated manifold assembly) is a disastrous mess. It is still the machine I use regularly. I will also take it outside and use the hose and plentiful tools to vacuum out my cars.
I had a Bissel Velocity Total Floors (can turn the brush off with a mechanical switch). This was a great vacuum … probably their best one. I cleaned it up and gave it to a good friend when I bought the reman Healthy Home. Afterwards, I bought a demo-model Velocity Pet (same machine with one extra tool for pet hair) for a song (it was missing parts) and then I found those parts years later. It sits, brand new and unused, in a closet.
I bought a Bissel Momentum for my Dad several years ago. This is almost as good as the Velocity but the air chamber above the dirt cup is smaller and dirt doesn’t drop out of the vortex as easily (more dirt dust makes it into the engine filter). This is still a pretty good vacuum and the one I brought to work was easily my best dumpster find.
I have a Bissel Lift-Off Revolution. Again, found it on clearance at Home Depot. Lots of interesting features, the most obvious is the ability to lift the engine off the chassis and carry it around like a lightweight canister. I’ve tested this one once, but it also sits new and unused. On the downside, the Lift-Off feature looks a bit delicate and I could see the electrical connectors becoming damaged if used without care.
Question for the group: It seems most (all?) brands have standardized on 12amp electric engines. Is that true for all residential brands, even the elite machines?
Originally Posted By: Bror Jace
...Question for the group: It seems most (all?) brands have standardized on 12amp electric engines. Is that true for all residential brands, even the elite machines?
Pretty much. Typical electric circuits in homes are 15 amps, 20 sometimes for kitchens and baths where high draw appliances will be used. If vacuums drew more than 15, they'd trip breakers on your normal outlets, and if they drew too close to 15 they might trip 'em anyway if lights and other things were on as well.
This is the same reason electric space heaters are all 1,500 watts, they draw about 12 amps. Amps x volts (120 residential) = watts.
jeff
Thanks greenjp. My first assumption was that the power limit was a gentleman's agreement of sorts with the carpet manufacturers. My thought was that more power would begin to degrade the carpets and get people complaining about "defective" carpet.
