Driving a 3/4 ton truck around unloaded is painful, half tons aren't great, Bilsteins help.
Please explain.....................
Sure... trucks built and suspended to tow a lot of weight and 4x4 typically ride harsh.
All the half tons are body on frame, some ride better than others, but they all ride like body on frame trucks, that is to say nothing like a unibody midsized like the ridgeline or a big SUV.
The solid axle 3/4 tons are harsher yet, and pound you death in the right lane unloaded.
One can compensate for this harsh ride by upgrading factory suspension components (like Bilstein shocks) poly or new bushings but a 2000'e era half ton 4x4 is going to be harsh ride in the right lane regardless.
The op said he'd use his truck like a truck so maybe he doesnt care.
Friend of mine had a late model (2015?) F250 for a couple years. Borrowed my Tundra for a quick spin on a bumpy road, said my truck rode way nicer... He traded down to a half ton not much later. !
The RAM actually rides insanely well, not just for a truck, but in general. It handles bumps and things better than my Jeep does, though the Jeep would hand it its rear on anything with corners even with the suspension tuned to "luxo-barge". It rides better than my dad's Town Car.
GM HDs drive quite smooth. Ford and Dodge not so much.Driving a 3/4 ton truck around unloaded is painful, half tons aren't great, Bilsteins help.
The 49 state solution to the manifold problem would be headers, but in Cali you cant really do that, so guys go with the magna flow replacement at 1700 a side.
The OEM manifolds are expensive,Ive lost one and had it replaced under warranty which was extended to 70K for that part as it was considered emission related in cali - so far so good with me on the rear end, I push it pretty hard, but dont abuse it.
The reason I have boat towing picts is that Im a part owner in a boat company so I see all these clients trucks
I see lots of guys with 5.3 that have rocker problems and AFM problems in general on Chevy trucks.
I see lots of 5.3 completely clapped out at 150K- the popular local lake is a brutal tow through the desert with lots of hills (hence the 117 degree pict) this route is hard on trucks towing with long wide open stretches to pull the hills.
On the fords I see can phaser and timing chain problems, and on the hemis the dreaded valve tick.
Maybe all these problems are actually cheaper and easier to fix though because there are so many parts available?
I recall reading you are a mechanic so you'd probably have sold grasp on that.
I will say this. I know my 2002 2500HD was a rough ride. My 2017 3500HD is really nice when compared to that. They certainly improved them, but empty on rough stuff it will beat you up.
If you put good shocks on, the front suspension last longer because you don't get the porposing. I just put Bilsteins on the rear of my 1 ton. Porposing gone. About 6 years into ownership of my 2002 I put KYBs on. The sure were nice when towing, not so much empty.
We have emissions testing here in DFW, But not like Cali with the visual inspections & CARB certifications on aftermarket parts.
I actually like the VK56DE/RE5R05A combination in the Titan/Armada, Outstanding power for it's displacement, It takes a LQ9 6.0L or L76 6.0L (Vortec Max) to hang with one & a L92 6.2L to outrun/outpull one.
The 5.3L has to rev it's guts out to pull heavy loads & none of the port injected ones had oil coolers where all the 6.0L/6.2L engines have oil coolers. I'm no engineer....But it makes a huge difference when towing in hot weather.
The Dana 44 was a poor choice when Nissan could have built a HD unit in-house with a 9+ inch Ring Gear, Or just use a Dana 60??
Absolutely no surprise here, but according to CKN thats misinformation. "You obviously dont own a truck. "
You can keep using the words "modern truck" over and over but it doenst really mean much other than you went out and bought a recent model year of an example that still has a relatively new parts on it. If you didnt get the 4x4 with a tow package it will ride a bit better than the examples that have these upgrades unloaded.
In terms of actual technology, you have a body on frame solid rear axle truck with IFS.
Pretty much the same as they have always been and what everything else in the half-ton category is and has been for the last 20-years.
The only thing really "new" in the segment is the front end on the new dodge which rides better than your chevy, which is about the same as the ford and everything else in the segment. Pretty much all of them ride better with bilsteins or kings than stock, new great parts make even old trucks ride pretty well.
Our last group get together had a new EcoBoost, new dodge, my ridgeline and an older avalanche.
The larger group also has a new chevy 1500, afew 2500's my Titan, 2017 tundra, a new taco, a frontier, a few big diesels, a canyon, and a bunch of small old toyotas.
No body on frame 1/2 ton truck comes close to the IFS/ IRS Ridgeline ride, and no 3/4 rides, as well as even an older half-ton unloaded.
I go out all the time and get to drive all the new stuff extensively.
I get you are happy with your newish truck but believe you are biased into thinking its something that it really isn't.
UD
