Originally Posted by dnewton3
This example is the same reason I don't run a bigger filter on my daughter's 2012 2.5L Fusion. It takes the FL910. It's easy to get an FL400 on there, but it hangs down past the protective structure. I had, for a while, a 2010 Fusion with the same engine. I decided long ago that "bigger ain't better" in this case. The UOAs on my old 2010 were stellar; it's not like the little FL910 was failing at it's job.
I dunno. I've used lots of FL400s filters on my 2010 Fusion with the 2.5, and I don't recall them sticking out past the plastic bottom cover. They do come about even with it, but that's about it.. and honestly, the cross member in front of the engine sits lower than the filter, and is in front of it, so it kind of shields it.
Having said that, I have also run FL910 filters on the same engine, and they seem to hold up fine upon inspection..
