I’m looking for a little advice here, I have been back and forth over vehicles for a while now. I bought a 5.3L avalanche with 4.10 gears for towing my 25’ 6000lb trailer. It does fine until there is any kind of headwind, and then it is difficult to maintain 60mph. It just doesn’t have enough power. I have considered repowering it with a 6.0L High Output engine, but that is going to cost around $6k (transmission included). For this price, I can get a different tow vehicle on a trade.
I had considered trading it in on a 2004-2006 Nissan Titan, which has dramatically more HP/TQ, but about the same fuel economy (bad). So now I am considering a ¾ ton diesel truck (same year range…around 60k miles) due to the pulling power and better fuel economy. Here are my requirements:
- around 60k miles;
- 4 full doors
- Comfortable ride (I think this rules out the ford SD)
- As short as possible (while still having 4 doors)
- 4wd (this will also get me to work in blizzards)
It seems like it is between the Dodge and the GM. I have always preferred GM trucks and so I am leaning towards a ¾ ton Duramax around 2004-2005. I have heard the earlier Duramax’s give better fuel economy (marginally), however I keep reading about injector failures. There is a warranty on them to 100k miles, but it costs at least $4k to fix an injector failure afterwards. The Allison transmission is considered the best light truck diesel offering. The GM is considered to have the best ride. To my own taste, I think this is the most attractive looking truck as well.
I don’t know much about the dodge, but apparently it has the best engine, but the transmission is the weak link. The dodge appeals to me because of the engine, and I consider the transmission not to be an issue (hopefully) because I would never abuse the vehicle or use any power adders. Plus, the vehicle won’t do that much towing and the trailer is light. This truck seems like would be the most durable and I think it is the shortest truck with 4 doors.
As for the Ford, I find the ride too stiff and the styling just not to my liking for whatever reason. As for the titan/tundra I have kind of ruled them out due to fuel economy and comfort. I think I would like driving them too much (like I do with the avalanche) and would end up driving too much in them and using too much gas. A diesel ¾ ton is too big and bulky for my daily use and will likely be used less often for driving (it will truly be used as a towing/snow day vehicle).
Can anyone give me their thoughts as to:
- the merits of the Dodge vs. GM diesels,
- and if you come down on one side, which are the most desirable years of either;
- how bad is the injector issue on the GM and/or the transmission issue on the dodge;
- other things to consider when buying a diesel with 60k miles (eg. I wouldn’t buy one with power adders).
Thanks in advance for your thoughts!
- around 60k miles;
- 4 full doors
