I took it that he knew he misspoke when he said it; slip of the tongue, no real biggie in the scheme of things.
I took it that the Media blurb was the lack of proper background reasearch and ignorance of the facts. Media needs to report as factually as possible; this was pure laziness on their part.
Captain Steeve also made some incorrect statements from 10:45 to about 11:15 regarding the design of the spherical bearing assembly.
The bigger point is that Boeing should have known better and called for a) shorter inspection and/or re-greasing interval or b) redesigned the joint altogether - over 14 years ago.
Boeing did redesign the spherical bearing assembly and suggested it with a new part number (See about 11:20 to 11:50), but left it to the airlines to install it. Perhaps using a "stronger"
language might have helped, who knows?
Where was the FAA and their supposed oversight in this matter? Why didn't they get involved and force the replacement and reduce inspection periods since they had the Boeing documents?
As a former aerospace scientist who had worked in Stress and Fatigue analysis, I think the spherical bearing race was either not thick enough, or did not have the proper heat treatment, or the groove had the wrong
profile.
One item that a stress and fatigue person learns early on, is that any groove or part is not to have a sharp lip or transition but should have a fillet since:
- Stress concentration is a problem of load-bearing mechanical parts which is reduced by employing fillets on points and lines of expected high stress. The fillets distribute the stress over a broader area and effectively make the parts more durable and capable of bearing larger loads. Wiki
Over time, a straight groove without a fillet will experience stress concentrations leading to failure which, in this case, was a splitting of the spherical bearing race.
