Carlostrece
$100 Site Donor 2025
As many already know, and some may not know... You can upgrade a Honda CRV Gen 2 battery from 51R to 24F. From my time spent at CRVownersclub.com I know that several other generations of CRV can do this same mod and upgrade to 24F. However, a few other generations might not be able to vertically fit a 24F battery. For any generation that can't vertically fit a 24F battery, they can upgrade to a 35 battery.
The rest of this post and thread is about Gen 2 and other gen that can upgrade to a 24F battery. For more info about other generations, please consult CRVownersclub.com.
This upgrade not only gives you a larger more powerful battery, but can save you money every time you buy a battery. 24F is a more common size, is more mass produced, and therefore costs less. It's also bigger and more powerful.
I'm in the process of upgrading right now.
Let's look at the economics of parts cost.
Most sources say you need to buy a Honda Odyssey battery tray to upgrade a CRV to a 24F battery. Some sources say you can modify and use the stock original CRV battery tray.
I've never done this mod on a Honda, but I did similar mods on 3 Jeeps. My past experiences and common sense suggest to me that both methods probably work, but buying an Odyssey tray probably requires less modification work/time and probably gives a better supported 24R battery (which might be helpful on bumpy roads).
I decided to go the route of buying a Honda Odyssey battery tray for $30 from my local Honda dealership because it's probably the faster and easier solution, and it's the most common solution.
Honda Odyssey battery tray part # 31521-TK8-A00 should cost $30 (or less) at your local Honda dealership parts dept. It cost me $30 at my local dealership, but some dealerships (in other parts of USA) advertise online $22 for this battery tray.
Now lets look at the cost and power of 51R vs 24F batteries and you can see why this is an economically attractive modification-upgrade. Prices and Warranties Jan 2026.
51R Batteries
Walmart Everstart, 500 CCA, 85 RC, $150
Genuine Honda OE 500 CCA, 85 RC, $162
Oreilly Superstart 500 CCA, 85 RC, $214
Those ^ are highend premium flooded 51R batteries. Their electrical specs are the minimum needed to be (marginally) acceptable for a CRV parked outdoors in a Northern winter climate.
There are economy lower cost (weaker) 51R batteries available, but I don't think less than 500 CCA is advisable in a Northern winter. IMO, 500 CCA is only marginally adequate in a Northern winter. It's better to have more than 500 CCA if you can afford it and fit it. With 24F you can afford more CCA and fit it.
As you can see below, having signifigantly more than 500 CCA actually costs less because 24F is a larger, more common size battery. More common size means more mass production, which means lower price even though it's more powerful. Yes a 24F will fit!
24F batteries
*Walmart Everstart 585 CCA, 95 RC, $80
**Walmart Everstart 600 CCA, 110 RC, $100-110, My favorite!
Genuine Honda OE 630 CCA, 120 RC, $170
Oreilly Superstart 585 CCA, 115RC, $120, I bought this one.
United Battery 550 CCA, ?RC (probaby 80-85 RC), $100.
There are even more powerful Everstart flooded 24F batteries available from Walmart and Oreilly. I think lots of CCA would be ideal in Canada, Alaska, Upper Midwest, Upstate New York, but in Western WA (where I am) I have no need for more than 600 CCA in a CRV. In my moderate winter climate 585 or 600 CCA is plenty of overkill.
For those in the frozen North...
Walmart Everstart 725 CCA, 130 RC, $140
Oreilly Superstart 750 CCA, 130 RC, $210
If you live in a warm Southern climate, there are low cost economy 51R batteries available, which are be fine in a warm climate. So in a warm climate I see no reason to upgrade your battery size. In a warm climate just buy economy 51R from Walmart, IMO.
Manufacturer and Warranty
Oreilly Superstart (made by East Penn) 1 year warranty.
Walmart Everstart (made by Clarios on Westcoast, East Penn on East Coast) 2 year warranty.
Genuine Honda OE (made by Clarios) 5 year warranty with 3 yrs full replacement, 2 years prorated. Honda OE battery prices are surprisingly good and competetive (much lower cost than Oreilly Superstart for a premium 51R).
The only bad thing about Honda OE battery is that AFAIK Honda only sells a (flooded) premium Clarios battery in 51R and 24F. Premium is ideal if I was buying a 51R because if buying a 51R it needs to be premium to get 500 CCA (which is the minimum acceptable CCA in my climate). However, if I'm buying a 24F then I don't need or want a premium (most powerful) 24F. When I'm buying a 24F I want an economy line battery to save money (and it'll still be more powerful than any premium 51R).
United Battery housebrand (manufactured by an offbrand that I forgot the name of). I don't recall the Warranty. The specs per price are uninspiring.
P.S. - @Nukeman7 introduced this topic and these concepts to me. I'm very grateful. I'm also very grateful to @f355spider for his excellent advice on this topic. I'm also grateful to everyone else who gave me excellent advice on this topic in other threads. I'm sorry that I can't name you all here, but my memory for names isn't that good. Please know that I appreciate you all.
51R Batteries
24F batteries
