Ultra low profile 1/4 10mm socket options
IS there not a special tool for valve clearance adjustment?
This is the special tool for valve clearance adjustment. I just couldn't get the inspection cover off a couple of the covers. Lol.
This is the special tool for valve clearance adjustment. I just couldn't get the inspection cover off a couple of the covers. Lol. View attachment 234865
Ah hah I see. I was mistaken about your request for a tool to do the clearance, not to get to a point to do the clearance check. I knew that Honda had one, sure Suzuki would aswell.
Can you do the inspection and adjustment whilst taking off the TB? Maybe that is for a reason....taking of the TB, perhaps for cleaning or some other inspection?
No doubt that the throttle body could use cleaning, but it barely runs at the moment.
Gas tank was full of rust and I cleaned that out. Fuel pump wire was smashed and I repaired that. I wanted to check the valves before I put the gas tank back on. If I end up having to pull the injectors off for cleaning, I may do the TB at the same time.
Here are a few pics of the clearance issues.
Last pic is successfully getting the new socket on the nut.
