Ultra low profile 1/4 10mm socket options
So I've recently run into a problem that I can't find a tool for that works.
I'm working on my uncle's Suzuki motorcycle and I want to check the valve clearance. The inspection cover has a recessed 10mm nut/stud under the frame.
I think I could get to these nuts if I took off the throttle body but valve clearance checks are part of regular maintenance and it seems stupid to have to do this.
The clearance is only about 1 inch between the frame and the recessed nut. I have a Koken Zeal ratchet and 10mm socket that just barely does not fit. It looks like I'm going to need a low profile socket that works with a wrench.
I see that Snap-on sells low profile 1/4 sockets that work with an 11mm wrench. I can't find the sockets individually on EBay and I'm loathe to pay the shipping on 1 socket from Snap-on.
Does anyone know if any company makes a similar low profile set?
Would something like this be deep enough? It doesn't ratchet, but its low profile?
Nah, AFAIK the Nano stuff is all considered impact rated and tends to be too much for delicate work when every thousandth of clearance counts.
Try this for a whopping $16 at any O'Reilly. These are my secret weapon for tight spaces
https://www.oreillyauto.com/detail/...tandard-6-point-metric-socket-set/ptt0/gm4234
Seen here Nano 10mm next to Powertorque 10mm. To be fair, the Nano is 3/8" dr while the PT is 1/4". No, they're not flipped; the Nano has to be larger at the base to accommodate the larger drive size.
OAL of Nano in 3/8" dr: .897"
OAL of PT in 1/4" dr: .667"
Either will accept a wrench instead of a square anvil, but the PT takes a much smaller wrench as seen
I don't own Nano stuff in 1/4" dr. I don't even know if they make it.
If anyone has Nano in 1/4" dr please get OAL of the 10mm
Then we need to compare major OD and hex size of flats. I can measure the PT for these two dims if we have Astro dims to compare.
Thanks everyone for the responses and especially thanks to @AutoMechanic and @D60. You guys knew exactly what I needed. I was in town and grabbed it at O'Reillys. I think this is going to work perfectly.
what bike is this? I'd like to look it up and see what you're dealing with.
This is a 2005 Suzuki Boulevard VZ800. The outer valve inspection cover bolts have an 8mm head and the inner cover studs have a 10mm nut holding down the cover. I'll post some pics in a bit of the clearances. I've had this one on hold for a few weeks until I could find the right tool.
I had browsed some of the Suzuki forums and everyone just advised to take off the throttle body, but screw that.
