Turn signal bulbs for '15 BMW?
Da Swamp
The left rear turn signal is going out. The manual says P21WLL, but the only vendor I've found with that code is RockAuto; and they're the basic incandescent bulbs that I've used in cars for many years. Here is a video of a young man replacing his taillight bulbs on an F30 chassis like mine, https://www.youtube.com/watch?v=iQOgsFi4Qpc, and they are clearly those kind of bulbs. Advance Auto has them too, 7506LL bulbs.
Is that correct, or has the 2015 BMW gone to LED bulbs?
Originally Posted by BMWTurboDzl
If' you're unsure (enter VIN) https://realoem.com
Thanks, BMW, but the screen comes up almost blank except for a link to something called "ezoic."
Weird. Try this https://www.realoem.com/bmw/enUS/select
Anyways that appears to be the correct bulb.
I found it with a search on DuckDuck Go. Yes, the bulb does look like the standard one. I can pick up a pair at O'Reilly's, and order a pair from RockAuto to have as a backup. Autozone tried to tell me they didn't have it because it was an LED bulb.
Originally Posted by Miller88
BMWs have turn signals?!
Sorry, had to
Like the Corolla and Sentra they're optional.
The easy way to tell is park the car, turn on the hazards and look at the turn signals.
If you see them dim up and down as they flash, they use incadescents
No dimming up/down = LED.
Sorry, had to
Especially among Swamp drivers. They are confused by all those stalks sprouting from the steering column -- so they just ignore them.
So what I'd see with an LED setup is
Bright
BRIGHTER !!!
Bright
and with the incandescents,
Dim
Bright!
Dim
Yes?
Bright
BRIGHTER !!!
Bright
Dim
Bright!
Dim
Yes?
LED is off, instant bright, instant off.
There is no filament on a LED to warm up and cool down
You can tell by looking at the assembly that there is a incandescent bulb needed by the back of the light and the reflector of the turns
[Linked Image]
[Linked Image]
Sorry, had to
It's not used but they have it just in case some weirdo decides to use it.
[Linked Image]
[Linked Image]
I just didn't want to disassemble the housing to look at the bulbs in situ, if someone would know which bulb to use. The basic 7506 is fine.
[Linked Image]
[Linked Image]
If you don't trust the BMW manual, then you need to go in and check.
7506 is Osram/Sylvania's part number equivalent for P21W. The basic 7506 is fine, but has reduced life compared to the LongLife that comes from the factory.
Originally Posted by rooflessVW
Go to the dealer and ask for a bulb.
You know, they'd even put it in for you!
This seems like the simplest thing to overcomplicate.
Sure, but I don't feel like selling a pint of blood just to get a bulb replaced. That's not a warranty item and the dealer labor rate is probably higher than I want to think about. Besides, I want to learn about this car as I have all my others.
Of course there is the 7506LL long life version from Osram/Sylvania which may be identical to the OE version
The Philips PY21WLL versions for the fronts and P21WLL for the rears came today from RockAuto. The existing bulb is operating without issue and I haven't seen an error message, so I'll keep the bulbs in the trunk for the future.
