Originally Posted By: 3Toyotas
Yeah, the 5.7. It's in my sig.
Not sports car performance towing necessarily, but it did outperform all other's with 7200lbs behind.
It's amazing how they compared the tundra to the turbo diesels. But it faired very well in the testing, even while towing. This is extremely impressive to say the least. I mean a truck with more tow capacity and more torque by a long ways couldn't keep up with the new tundy.
Yeah, the lightning and the SRT 10 are slightly faster but not by a long ways from what i've read.
That's the thing with me too is, when i hook onto my fifth wheel and set the cruise at 70mph. I want to go 70 up or down hill, no matter how steep the hill. And this tundra has not let me down yet that way. Jeez, my dad's tundra tows a 9k lb 5er and he has no problem staying the speed he wants. NOt only does it do it without flinching, but it even manages between 9&11 mpg doing it.
My bad on the IIHS ratings. Should edit my post to read NEAR the top i guess. Looks like ford edged out the tundra in one category. But does that ford have TC, BFD, VSC, All airbags, anti locks so it can possibly avoid an accident all together? Probably not. Thanks to these so called nannies, many tundra owners have avoided accidents because of them.
It's amazing the oil burners couldn't match the tundra while towing HALF of their max tow capacity. Kind of funny if you ask me. The tundra with 75% of it's capacity, and the oil burners at 50% and they couldn't out do the tundra....Wonder why?
There's the arguement of " well the diesel will outlast the gasser by a long ways". Will it though. From what i understand, the dummax is a 200k mile rebuild motor. So basically you'll need to rebuild it then. The dodge is supposedly a 4-500k rebuild motor. Don't remember on the powersuck.
If i actually HAD to have a diesel truck as of right now, it would be the dodge with the cummins pre 06. Hopefully it would have the Aisin transmission in it. But i don't tow cross country a lot, nor do i need to tow 16k+ either. Only need to tow 11k maximum, and that's only a few times a year. I mainly tow 7500 lbs during the summer, from may until october for an occasional weekend here and there.
Considering the higher fuel costs of diesel vs. gas, and higher maintenance cost, i think i'll stick with my gasser.
You cannot, with any respect to sanity draw any conclusions comparing the SPEED of a diesel and a gasser in towing. The Duramax has 200+lb-ft on the gasser in the Tundra, at HALF the RPM, over a MUCH flatter curve. It also has a big honkin' turbo.
It begs the same question as to why you never see a gasser pull as well as the diesels at the truck pulls.
I'm NOT a GM fan, but to compare the towing capacity of the Duramax to the gasser in the Tundra is silly. And drawing conclusions because the gasser was "faster" is even more ridiculous.
It is like me stating that the 5.4L in my Expedition is better than a C7 CAT engine because I can get to 60Mph with 7,000lbs behind it faster. Speed is not the reason Diesels are used for heavy towing.
NHHEMI summed up the Lightning/SRT-10 comparison pretty well
