Toyota Resale Values Tank
Originally Posted By: mstrjon32
Originally Posted By: 3Toyotas
The 6.0 / 6speed combo has proven it cannot pull ANY slight incline in 6th gear.
So many things you've said in this post are so ridiculous it's not even worth arguing with you. But this is particularly off-the-wall. The point of a tall top gear is for economy under a no-load condition. When you start to climb a grade, it DOWNSHIFTS for power.
But I'm not surprised that you're looking for basically anything and everything to point out as a flaw. I'm sure if your Tundra had a tall 6th, you'd be bragging about how the GM truck is a gas guzzler that has a pointlessly powerful top gear and your marvelous, wonderful Toyota is the fuel economy star.
Please, spare us the [censored].
It is a known fact the 6.0/6-speed combo CANNOT pull it's own weight in top gear. All you got to do is nose around over on the gm forums to know that. From what they say over there, with the cruise set on the freeway coming to a hill, the truck looses speed by 8-10 mph before it shifts down. Then it doesn't go to 5th like it should do, it goes strait to 4th. Usually they even have to punch the gas to get it to drop down. Note: these are the folks with 3.73 gears. The 4.10 guys are a little happier.
So GM did in fact screw up with the gearing for sure. Gee, toyota must have known something here to put in 4.30 gears. Wouldn't you say?
Matter of fact, they also say they're not happy with the mileage.
Yes, my tundra does get better hiway mpg than the 6.0 and some others. But it doesn't matter anyway.
Do your research before you call [censored] on me buddy.
Hundreds of toyota motors across the country are logging as many as 1 million miles.
Please provide proof.
Because last time this discussion came up, we had easily verifiable examples of Ford, GM, and Volvo products going over 1 million miles on the original engine, but only unverifiable rumors of one Toyota doing so.
Surely, with there being hundreds of 1 million mile Toyotas out there, you should easily be able to provide us with several examples.
Or perhaps you've just been drinking too much of that rising-sun kool-aid.
Just for you, 3Toiletas: http://www.millionmilevan.com/
A ~1.1 million mile Ford 5.4L-powered Ford van. Be sure to note some of those oil change intervals. Can you imagine a Toyota sludger lasting over 1 million miles with 55,000 mile oil changes with conventional?!
I'm not denying the fact there are domestic autos with 1 million miles. Never have.
1 million miles on 55k oil changes? Now that's beleivable.
Speaking of Toyota frame rust, 3Toyotas better be wary of 2-post lifts or else this might happen to that shiny new Tundra of his in a few years:
This guy jut loved what Toyota did for him.
And speaking of the Tundra's frame rigidity (funny):
http://www.youtube.com/watch?v=EWjTbiYo3x0
and
http://www.youtube.com/watch?v=zRfE_XAk2mE&NR=1
Is the term "pos" applicable here? I think so.
NOt interested in your links to be honest.
Anyone that puts a lift on their truck are asking for repair issues.
and
He's not talking about lifting the truck; he's talking about putting the truck on a lift or hoist.
Actually, the '07-up Tundra 6-speed has a taller final overdrive than the TorqueShift. So much for holding overdrive up a grade for 3Toiletas!
Toyota AB60E - 0.588:1
Ford 5R110 - 0.712:1
Facts, they're what's for dinner.
Actually it does just fine staying in 6th most of the time. You forgot it's got a 4.30 rear end in it. NOt a car sized 3.43, that shouldn't be used for towing to begin with.
I haven't forgotten anything. What you don't realize is that your truck isn't holding 6th gear up any sort of incline with a decent load on it.
YOu are reading into this all wrong my friend. Never ONCE did i say it would hold top gear with a load in it. Actually, i pull my 7500lb fiver in 5th on the flat. What's nice is when i come to a hill at 70 mph, i have 2 other gears to pull me up the hill at the SAME speed. Depending on the hill, usually 4th does the trick.
Naturally you aren't interested in my links. After all, you might see something you don't like.
I definitely wouldn't click on the 2nd link if I were you, being that it is an actual, semi-relevant, scientific test.
Vehicle lifts are a fact of life in auto repair, if your truck ever visits the Toyota dealer you can bet it will see its time on a lift. Better hope that frame doesn't rust!
Then what exactly ARE you saying in this quote:
If you have a 6 speed, and it has a 6 speed, and you are dogging it because it won't pull weight up hill in top-gear, but then state you don't pull weight in top-gear either? It sounds like you are ripping on it for the sake of ripping on it, or making a point that doesn't exist here?
When my Expedition comes to a hill, it just unlocks the converter... if the hill is big enough and the cruise it on, it'll drop a gear, accelerate, then re-lock the converter. It doesn't appear to need more gears, in fact the combination of converter lock/unlock and its current gear selection seem to be more than adequate. The 6th gear in the current crop is for increased economy, not towing prowess.
Do you honestly think your Tundra will hold overdrive up a grade as well as a PSD?
Do you understand how a turbo works? Do you understand that it can build boost (and thus torque) independent of RPM?
I don't believe so. Otherwise we wouldn't be having a gas truck being compared to a diesel with almost twice the towing capacity.
I really don't care how fast my truck is empty; all that does not excite me. Well, maybe once in a great while to blow away that hemi or titan. But what i use my truck for 90% of the time is towing trailers.
That video has nothing to do with loading our trucks whatsoever. Just so you know, all real trucks bounce a little.
And Toyota knows real trucks, which is why they had frame rot problems spanning more than a decade right?
They've been making "real" trucks for only a couple years. I cannot think of any truck from Toyota, used for real WORK produced during the 60's, 70's, 80's or 90's, can you?
The argument that Toyota then knows more about making trucks is ridiculous. They copied the F-150 so blatantly it is hilarious. My uncle has a Tundra. It's like stepping into a Ford.
Quote:
So this is just another desperate attempt by the big 3 to reduce their market share losses to Toyota. Plain and simple my friend. Pretty cheap [censored] marketing efforts on their part, i'd say. Couldn't find anything else in their 80's stlye drivetrains, so they got to play their own little games. Pathetic.
80's style drivetrains? Toyota didn't even HAVE a 1/2 ton drivetrain in the 80's! That's almost a compliment, given that EVERYTHING Toyota has learned in the truck market is what they've copied from the Big 3.
Quote:
As far as rigidity in the frame, i think you need to do a little more research. What type of frame is on big tractor trailers? They are C-channel. Why? because they are less likely to brake when loaded heavy. They have more room to flex, whereas a full boxed frame (ford) is more likely to break when loaded heavy.
We are talking about 1/2-ton frames here, not something found in a Kenworth, which is REQUIRED to afford twist due to the sheer mass they pull and the several THOUSAND lb-ft of torque those huge diesels produce, something your 1/2 ton truck is NEVER in a million years going to come close to. Remember, Ford makes up the F-550, they know a thing or two about making trucks larger than a 1/2-ton, and have been doing so for much, MUCH longer. Way before Toyota started capitalizing on the domestic truck market. As have the other two.
Quote:
So, which one is better? i'd say C channel which is what's on the tundra. Under the cab it is reinforced C-channel, and in front of the cab it is fully boxed for better crash protection.
Of course you would. Because you believe everything Toyota does is superior.
Quote:
I'm not super happy with the interior, but i'm certainly not dissapointed with it. I think toyota could have spent more time designing it, but most of their efforts were focused on the drivetrain. Of which, they did a fine job. Much more technologically advanced than the big 3 counterparts.
What?
Technologically advanced? In what ways? Please elaborate here. Is it the 381HP out of the overhead camshaft engine? Because that's not new technology. And Dodge is squeezing 390HP out of their 5.7L now.
Quote:
Better trucks from GM, Ford, Or Dodge? I wonder why they can't compete then? Still the old style push rod motors with almost the same HP numbers they've had for years. Especially the 5.4 triton v-8 POS. Then the dreaded 4-speed transmissions, which are a joke when towing.
1. The pushrods in that Dodge make more power and take up less space than the engine in the Tundra.
2. The 5.4L "POS" made 425HP in the Cobra-R, and they have TWO models making similar figures in Australia in the Falcon. Yes, out of less displacement than your Toyota. Also, the 5.4L/4.6L engines are also overhead cam, NOT pushrod.
3. The 4R100 is a very competent transmission, proven to handle ridiculous power levels. I have one in my Expedition.
Quote:
GM has made an attempt here, but yet again they have failed. The 6.0 / 6speed combo has proven it cannot pull ANY slight incline in 6th gear.
So Why are they riding on old technology?
Define old technology? The Japanese are riding on technology they borrowed from the Americans and the Germans.......
Quote:
It all comes down to being able to AFFORD to gain new technology my friend, and none of the 3 seem to know how to.
The Japanese government paid for the development of the Prius. Who's affording what here?
Quote:
Or they think they don't need to, or both. Probably both.
What exactly have the Japanese pioneered? What sort of bold technological advances have they given the automotive world?
Never heard or read anything on frame rot. Wonder why i've never experienced that in over 20 years with toyota?
This is a HUGE, well documented issue with Toyota issuing a RECALL over it, and REPLACING trucks!
Google -> Images -> Toyota Frame rot. Browse away.
Here's a link to info on it:
http://www.toyotanation.com/forum/showthread.php?p=2349601
Sorry, it was FIFTEEN years, not 10.
Quote:
If they've only been making real trucks for a couple years, why are they more technologically advanced.
In what way are they more technologically advanced? You keep saying this, but cite no examples.
Quote:
I think Hino has been around for a looooong time, which is owned by toyota. Matter of fact, the rear end in the tundra is made by Hino. Yeah, it's about as beefy as some 1 ton trucks.
HINO was founded in 1942. Another WWII gem like Mitsubishi. They joined Toyota in 1967. They produced Renault cars (under license from Renault) for sale in Japan for a number of years. They stopped making cars after they joined Toyota.
GM owned White, Chrysler owned Western Star, and Ford made their own large transports that are much larger than the small HINO "get arounds", but that make sense given the geographic differences between Japan and North America.
Quote:
When did i say toyota knows more about making trucks? I don't beleive i even said that.
Isn't that the message you are saying here by constantly saying the Tundra is better?
Quote:
Copied the f-150. That was a good one.
The similarities between the previous gen Tundra and the F-150 are MANY.
Quote:
Toyota didn't have a half ton truck in the 80's tells me they had plenty of time to perfect it.
Now that is funny!
Quote:
Copied the big 3? Where did they do that? Standard 4-speed; NO.
Well, they are producing a vehicle NOW, that they other three have been producing for decades, and borrowed numerous features from them. I'd call that copying.
Quote:
Old style single overhead cam? NO. 3 stage fuel pump? 2 stage induction system? dual timing chains for intake AND exhaust gases?
Can't see where they copied them with the motor anywhere.
Ford was using DOHC in the 1950's! This is NOT new technology! The 427SOHC produced by Ford in 1964 made 657HP. What kind of technological marvels was Toyota churning out in the 60's?
The Modular motor is no less advanced than the Toyota engine, but has more than a decade more use behind it, MASSIVE fleet use in law enforcement and taxi service....etc.
It was available in DOHC AND SOHC configurations, and currently in an SOHC 3-valve. The use of SOHC in the trucks is for superior torque production according to Ford engineers.
For 2000, the Tundra's largest engine was a 245HP 4.7L V8 with 315lb-ft. That same year, Ford was fitting the Cobra R with a 425HP 5.4L, and making 320HP out of the 4.6L in the Cobra. That's because the Modular has more duties than just a single chassis..... Similar to how GM's LSx engines do duty in both their trucks and the Corvette......
I applaud Toyota's upgrade to the 381HP 5.7L, but the figures are not due to superior engineering; Ford was making more power with less displacement almost a decade ago using dual overhead cams on the 5.4L.
As far as two-stage induction, again, Ford has been using this since the early 90's. The Lincoln Mark VIII had it, as did the Cobra. Not a Toyota first. In fact it would look like they are just following Ford......
Quote:
MY half ton is designed for what i need it to do, so that's all that matters to me. Toyota knows that it's what most people need their truck for as well; to tow 10k lbs or less. Most people don't need to tow 8-10 tons around.
But you are comparing it, and claiming superiority to a truck rating to carry 16,700+lbs.
Quote:
If you do some more research with those engineers who know more than we do on frame strength, then you'd know that a c-channel frame is much less apt to break.
Ford isn't having frame breakage issues. I'm sure they employ quite a few engineers.
Quote:
I'm talking about the POS 5.4L they're putting in the f-150's, and has nothing to do with the cobra.
But it has everything to do with the Cobra. They are the exact same engine family. The Modular series. I can swap a 4.6L out of an '03 Cobra into an F-150, slap a set of twins on it and make 1,000HP on the stock guts. Can you do that with the Tundra?
The 5.4L is not a POS. I have one in my Expedition mated to a 4R100. It works very well, we've owned three of them.
Quote:
I will have to say though, that Ford has more going for them now more than the other 2. They got wise just in the nick of time, and hired a big time money guy to shape things up for them.
Koodos goes to that guy.
Drive what you want though, it's all good. I'm happy.
No need to get all [censored] over the situation. It's all fun.
I am driving what I want. I simply want to inject some reality here that the comparison being made is not a good one. You are comparing a gasser to a diesel and drawing conclusions. You cannot.
I'm awaiting Hurricane/BOSS. It should be an interesting twist to the current truck line-up.
YOu are reading into this discussion completely wrong my friend. I am saying the tundra is superior in performance vs. the big 3 for WHAT IT IS DESIGNED TO DO. Period.
I agree, the f150 is similiar in a few things. But definately not stock HP or TQ ratings with the 5.4L.
From what i have read, the stock 5.4L ford puts down 200 RWHP. What a joke, and a huge drivetrain loss.
The tundra puts down 300 RWHP, bone stock. 320 ft/lbs at 1500 rpms (crank). Yes, 1500 rpms. For a gasser that is impressive.
I guess if you say toyota's copying the big 3; i guess you're right then huh?
HP per Liter, toyota has always been impressive in STOCK motors. Usually in the 60's. This 5.7 is 66.84 HP per liter stock.
The hurricane boss will be interesting, if ford can get that power to the ground without huge drivetrain losses. But toyota will have D.I. up their sleeve then and it should get interesting. From what toyota execs. say, this 5.7 is capable of 500 hp with a few adjustments and direct injection. After all, this motor is a lexus design off of the 4.6L.
Originally Posted By: Win
When I used to do the car auction thing, it was routine to see big 3 diesels pulling a Take 3 or bigger, fully loaded with cars or trucks, and doing it with ease.
Comparing a Tundra to trucks like these is absurd. I expect a load that these work trucks pull routinely would literally tear a Tundra into two halves. A Tundra might be okay for pulling a boat, but I gave our old '97 4.6 Expedition to our daughter and son in law, and they use it to pull their boat. My son in law says the Expy with a 4 speed pulls better than their 2004(5?) 4Runner with the 5.7 that is being canonized here.
Don't know what this has to do with Toyota resale value, though. I would expect that the plunge in quality and relatively poor value for the money, especially used, are the chief drivers of that.
Having thought about it, I don't think their 4Runner has a 5.7. It may be something like a 4.7 V8.
Take 3 or bigger with a 3/4 ton? Wow, i'd say they're taking some risks there. NOt smart.
Why is it compared to the diesels then? Because the good ole big 3 didn't have anything at the time to compete.
Obviously, you don't know much about toyota products. The 4runner has the 4.7L v-8 which is not impressive towing IMO. I've had 3 vehicles with that motor, and the hp and tq curves are not impressive at all. It's a great proven motor, but lacks some power curve to it and it gets worse mpg than my 5.7.
I could never get better than 16 out of either rig i had with the 4.7. My 5.7 at 70 mph delivers 20 mpg. Over that speed, and it goes down.
5.4 exy pulls better than the 4runner. Of course it would handle it better because it's bigger and heavier. But i noticed you didn't say it had tremendous amounts of more power. WTH?
I'd bet the power is pretty close. But then again, the 4runner is AWD so you lose some power there.
In case you haven't noticed, ALL makes and models are tanking.
Originally Posted By: firemachine69
Hino is now rolling scrap. No kidding. They're the ONLY manufacturer who can't make medium and heavy duty commercial vehicles to last beyond 200K miles...
Honestly, i don't think many auto related industries are doing well at all right now.
Last beyond 200k?
What?
Now that is funny!
Which 5.4L is putting down 200RWHP? The 310HP one from the current F-150 or the previous gen 260HP one? Make sure you are checking the right engine. Interestingly there are MANY 4.6L Mustangs putting down 300HP to the tires with VERY slight mods from their 300HP 4.6L's.......
The current 5.4L makes 310HP, and 365lb-ft; 320HP and 390lb-ft on E-85. It also is mated to a 6-speed auto. And has an 11,300lb towing capacity. Hurricane/BOSS should mix it up a little, but we are not talking a huge torque difference, even given the .3L of displacement difference.
We don't race or tow with dyno's. My cam grinder's 'stang went 11.19 @ 120+Mph with a touch over 300RWHP. I've made your Tundra's RWHP numbers with stock junk on a 330,000Km 302, giving up .7L of displacement.
How a truck shows on a dyno has very little to do with how it is going to work in real life. A loose or unlocked converter has a massive effect on the dyno results.
Ultimately, I think the HP numbers are being read into far too much, and being used as a basis for "performance" here, which is why earlier, I brought up the SRT-10 and the Lightning. Obviously much more power has been done. Why it is not currently being done; why the 5.4L from the Falcon isn't in the F-150, well, I am sure there are reasons.
I didn't give them a 5.4 Expedition, I gave them a 4.6 Expedition.
I know the 4Runner 4.7 V8 has lousy towing capability - I was trying to be polite by saying the 4.6 Expy could easily out pull it.
You're right in that I don't know much about Toyota / Lexus cars because I have not been interested in purchasing one in the last two decades or so.
Well, maybe a Pontiac Vibe to haul the dogs to our lake home would be an exception. I am interested in one of those.
Maybe with resale values tanking I can get a deal on slightly used one.
I'm talking EMPTY with NO LOAD. Exactly! Got it?
My truck CAN pull most slight hills in 6th gear no problem. Put a little weight in it, and it will probably go into the TC in 6th but that's it.
So yes, there is a point here and an issue with the 6.0L/6-speed/ 3.72 rear end. I do not experience this issue with my 6-speed. Read up on the gm forums for assurance.
I don't pull a 7500 lb fifth wheel in 6th. That's not the right way to tow trailers. Actually toyota says to leave it in D mode and tow haul. I don't like it going into 6th when i'm towing unless it's a nice long downhill descent. But i have control if i use sequential mode to decide what gear to use. But when i come to a steep hill, i put it in D mode so i gain WOT in gears 1-3. S mode i lose WOT, but it still holds gears longer. ???
Your expy does exactly what my 02 tundra 4-speed did when i come to a hill. First drop in speed, the TC would unlock, then drop if need be to 3rd TC unlocked then it would lock again until noticing less throttle response.
There is simply NO COMPARISON between a 4-speed and a 6-speed while towing. The difference is night and day. You no longer have just one gear on hills, you have 2 or 3. Not only that, but the rpm's are lower as well if you don't go too low on speed. 4th gear on my tundra at 70 is in the low 3000's. I think my 3rd gear in my old tundra was about the same (3000). Which is where i had to tow in (3rd).
So a 6-speed is a must have while towing from my experiences.
Talking empty or towing?
Empty on SOME hills, yes it would. Larger hills, probably not.
Pulling a trailer up a hill AND maintaining the set speed, my truck will drop a gear or 2 depending on the hill. Yes, sometimes it will be in 3rd at 70 and 4000+ rpm's. But the key is here, that it is in fact holding the set speed. It doesn't bother me at all for the motor to be turning that high of r's when it's pulling hard. Old school thinking, it doesn't hurt the motor doing this. It's when you're racing it with little to no coefficient drag or load on the motor is when it's not good.
I don't understand a lot about turbos. Just know they provide more power to an engine. That's what just blows me away.
Why can't i get an answer to why the TURBO diesels COULD NOT keep up with the NA 5.7 gasser?
They were brand new 07 trucks tested, so does it take a long time for diesels to get full hp tq numbers after break in?
But that's a different rear-gear combo than you have. With a similar rear-end ratio, is the behaviour not the same?
Nor is there between a gas and diesel.
The 5R100 is fantastic (Super Duty) I've found for towing. The turbo with the diesel makes towing ridiculous. Got load? You've got boost! Full torque at ANY RPM.
I think that's the thing that isn't getting across here. 0-60 times and the like, compared to a truck that is close to 8,000lbs (Jon's duty is 7,986lbs on the truck scales) cannot convey they feeling of towing a LOT of weight with a diesel and how that turbo changes things.
The 7,500lb ceiling here should immediately exclude the diesel. It is a joke for those trucks, the F-250/350 'duty has an 18,700lb towing capacity, the 450 will tow 24,500lbs; that's your 5th wheel and entire truck twice.
Gas to gas, compare it to the HEMI if you want to talk E-wang/HP figures. 390 vs 381. But in the big scheme of things they are all capable. There's a reason the F-150 is STILL the best selling truck. If the Toyota was really as superior as this paper comparison portrays, do you think this would be the case?
Just to clarify: I'm not saying its a bad truck. I'm just saying I don't think it's as good as the argument presented is trying to convey. It has tough competition with companies that have had trucks as their bread and butter for decades.
Diesels are NOT FAST. That's the part you are COMPLETELY missing. Their forte is moving massive amounts of weight. When your gasser is screaming at 4K, the diesel is making 600+lb-ft via the help of that turbo at 1,500RPM.
The diesel has stopped making power when your gasser is just coming on. Most of them are done by 3,500RPM, some even lower. Since they lack a substantial RPM range, they are not FAST.
That is why this comparison is so goofy.
All i know is it was the 5.4L f150. I thought it was the 300 hp motor.
The boss hurricane will be interesting, that's for sure.
The LS 6.2 GM truck is VERY close, and just edjing the tundra slilghtly in all categories. Except towing up a hill; which the tundra just barely took it. Interestingly enough, the HP/TQ curves are so so close between the 2 it's crazy. Of course though, GM is dropping the ball again on this motor. It's only available in one model and not the entire lineup. I'm sure it's a cost thing.
Dino's really don't tell us all that much really, and real world is where the difference will be.
I know for a fact the 6.0L GM HD trucks with the 4-speed CANNOT compete with my truck. Not even close pulling trailers. My bro in law has an 05 slighlty lifted, with a chip and could not keep up with us on our trip last summer. And he was filling up more often than us, and we have about a 8 gallon smaller gas tank.
From Utah to disneyland is where we went. We set the cruise at 70, and never dropped speed on any hill. The 6.0 however, really struggled especially on the hills. He hated the fact it was always in second gear on the slightest incline screaming like a bugger.
There's some real world pulling for you.
Final drive may be similiar, i don't know. I compared the final drive ratio's and they're fairly close.
But it's not working out for the GM owners with 3.73 rear end gearing. Like i said though, the 4.10 guys are okay with things.
I beleive the toyota 4.30 adds a tremendous amount of torque and/or pulling power to the engine. I mean, don't the truckers have like 5.00 gearing or something like that? Yeah, not a comparison but still trying to make a point. Offroaders use mid to upper 4's i beleive.
I am leaning towards the 6.0 not having enough low end torque to pull much in the lower rpm range. And i would think it's due to the higher rear gear.
No comparison between a gasser and a diesel? From what everyone says, the diesel is THEE choice for towing prowess. Performance wise according to the tests, IMO they are not. At least for the most common under 10k lbs towing segment. But hey, i have not had the pleasure of being able to compare a real world towing performance test yet.
But i will very soon. My cousin has an 08 duramax, and he just got a big 5th wheel. So we shall see soon enough i guess.
If you haven't noticed already, i'm more performance minded when towing. When i come to a hill no matter how steep it is, i expect the truck to be able to do the speed limit or more. And i'm telling you, my tundra has not let me down yet. Even our 9k lb horsetrailer hasn't set me back on hills.
So what you're saying is; the real test between the 2 would be to max out each truck (tundra-10,300 and f250-18,700) and do a real world test? I am totally up for that, and i think it would be a fair test. It would surely be interesting....
I'm so impressed with the pulling power of this tundra, i have been aching to compare the differences climbing a hill with a diesel just for fun. My thinking is it would be very close.
Don't blow this out of proportion; i'm talking performance here. The diesel CANNOT be modded either, and 2007+.
Just for fun.
