Originally Posted By: oliveoil
I think it's a software issue. To many electronics.
The problem is Toyota's poorly written, and implemented code. There is no fail safe in the design. If it "crashes", it goes to wide open throttle. GM and Ford setups automatically default to throttle closed. Toyota has been critisized in the past for its poor programming.
Originally Posted By: crazyoildude
what was wrong with a cable pulling on a throttle??
Nothing, Nothing at all i guess it is cheaper to use electronics..
Not really cheaper directly, but indirectly it is cheaper and more efficient. When all you have connected to the throttle pedal is a rheostat, or similar, it allows many things to be implemented cheaper and easier. Cruise control for example, on a cable controlled throttle car, requires a computer, and a vacuum system and another cable, to control. With TBW, it is simply a matter of the computer telling the motor at the throttle body what to do. It also allows for more efficient communication between the pedal and the transmission. Throttle by wire has a lot of benefits, when done properly. And Toyota just screwed it up. Simple as that. Much the same way Ford screwed up when it designed the cruise control chips in some of it's cars to be supplied with power all times, and located it right next/above the brake booster/master cylinder.
