Originally Posted By: Shannow
And the first two responses were provided in the most "simple" manner...complication and obfuscation.
Really? How was my answer "complication or obfucastion?".
If an XW-20 is too complicated to use in a vehicle specifically designed to use another xW-20, and rigorously tested to use an xW-20, then what hope does the average Joe have but to use the exact same oil as used in the test...let alone anything else.
It was spec'd for a 5W20 oil; I was simply letting him know that 0W20 oil carries the same hths spec despite the "0W" part, because it does--and to alleviate some of the inevitable "that's to thin" (which of course has already started), because it's just as "thick" as what's spec'd for the vehicle.
To the OP, I reckon that you are on a solid footing using that oil in your motorhome. If you choose any reasonably premium brand in the recommended viscosity range you'll be better than the average mug.
So, you're saying basically the same thing I am, but just want to complain...gotcha...
It's sad the guy comes on an oil site and is just met with a bunch of nonsense for just asking a question.
